Call us overprotective sign in issue
Marg Gaske 0 Reputation points
2026-02-13T08:35:54.38+00:00
Every time we try to log in to our microsoft account, we get a requirement to sign in and a then a call us overprotective error message which requires a code to be sent to a phone number. The code is never sent to the number and we cannot log in with any other method
Microsoft Security | Microsoft Authenticator
    2026-02-13T08:36:04.1366667+00:00
    If you're encountering the "call us overprotective" error message when trying to sign in to your Microsoft account and not receiving the verification code, there are a few steps you can take to resolve this issue:
    1. Check Phone Number: Ensure that the phone number associated with your account is correct. Sometimes, errors can occur if the number is not formatted properly or if the wrong number is registered.
    2. Alternative Verification Methods: If you have set up other options for security verification, try selecting Other verification options during the sign-in process. This may allow you to receive a code via a different method.
    3. Clear Browser Data: If you're using a web browser, try clearing your browser data or using InPrivate mode to see if that resolves the issue.
    4. Different Network: Attempt to sign in using a different network, such as your mobile data, to rule out any network-related issues.
    5. Contact Microsoft Support: If none of the above steps work, you may need to contact Microsoft Support for further assistance. You can reach them through the support page and provide them with the necessary information to help resolve your issue.
    Remember, if you have two-step verification enabled, you will need access to at least one of your security methods to regain access to your account.
