help me pls
daniel lin 20 Reputation points
2026-02-12T20:25:03.91+00:00
Hi Microsoft. Im stuck i need you to see if you can help me with Identity verification
Microsoft Security | Microsoft Authenticator
    2026-02-12T20:25:41.2766667+00:00
    To assist you with identity verification, you will need to ensure that the personal information you provide matches the supporting ID documents. If your identity verification is in a Rejected state, no further action is required, and your account will be suspended. If it is in a Challenged state, you must present verifiable credentials to prove your identity. Make sure that the user details on your account match the details on the government-issued ID document you provide. If there are issues with obtaining the verifiable credentials, refer to the help provided on the relevant page.
    If you need further assistance, you may want to create a support ticket or contact Microsoft support directly for help with your specific situation.
