Artifact Signing is stuck "In Progress"
Emil Wagman 0 Reputation points
2026-02-12T07:41:15.5266667+00:00
I have completed email verification two days ago, but it still says that we need to complete it.
Any help I can get here?
Artifact Signing
Artifact Signing
A fully managed end-to-end service for digitally signing code, documents, and applications. (formerly Trusted Signing)
    2026-02-12T07:41:28.16+00:00
    If your Artifact Signing status is still showing "In Progress" after completing email verification, it may be due to a few reasons:
    1. Processing Time: The processing of your identity validation request can take from 1 to 7 business days. If additional documentation is required, you will be notified via email.
    2. Verification Completion: Ensure that you have followed all the steps required for verification. If you missed any part of the process, it may still be pending.
    3. Contact Support: If the status does not change after a reasonable amount of time, you may need to contact Azure Support for assistance with your identity validation request.
    You can check the status in the Azure portal at any time to see if there are any updates regarding your request.
