I've spent 2 week trying to get IMAP to work on outlook, which has just stopped working..what are Microsoft doing to fix this issue
Declan Fallon 0 Reputation points
2026-02-11T14:47:45.95+00:00
I've been asking Microsoft help to help fix IMAP issues in my outlook. I've had 2 case number over 2 weeks now but Microsoft are not helping to resolve the issue. I pay for 365 and it's not working properly.... someone please help me!!!!!
Microsoft 365 and Office | Other
    2026-02-11T14:47:57.5966667+00:00
    It sounds like you're experiencing significant issues with IMAP in Outlook, which can be frustrating. If your IMAP account is not downloading messages, it may be due to the IMAP server not supporting the UID SEARCH command, which is necessary for Outlook to function properly with IMAP. This issue has been noted in Outlook 2013 and 2016, where the connection closes after sending the UID SEARCH command without downloading emails.
    To resolve this, you should contact your Internet service provider (ISP) or the IMAP server manufacturer to ensure that the server supports the UID SEARCH command. Additionally, keeping your Outlook and Windows software up to date can help prevent connectivity issues. If the problem persists, consider using the Microsoft 365 support tools to diagnose and fix common Outlook connectivity issues.
