How do I reset Surface Go 3 without login?
Chris keable 0 Reputation points
2026-01-26T11:54:39.05+00:00
I have 2 surface go tablets that my sons used. They have both forgotten their logins. I want to reset them deleting everything and starting again. How do I do this?
Surface | Surface Go | Install and update
  1. Huy-K 13,985 Reputation points Microsoft External Staff Moderator
    2026-01-27T03:17:36.35+00:00
    Dear @Chris keable,
    Thank you for posting your question in the Microsoft Q&A forum.
    We apologize for any inconvenience you may encounter when using our services/ products. Based on your description, kindly try these following steps:
    Reset from the Windows sign-in screen
    • Turn on the Surface and stay on the sign-in screen> select the Power icon (bottom-right).
    • Hold the Shift key (use a Type Cover keyboard if you have one), and while holding it select Restart.
    • On Choose an option, select Troubleshoot → Reset this PC.
    • Choose Remove everything (this deletes accounts, apps, and files). Restore or reset Surface for Windows - Microsoft Support
    Reinstall using a Surface USB recovery drive
    Step 1: Create the USB recovery drive (on another Windows PC)
    • On another Windows PC, download the factory recovery image for the Surface from Microsoft’s Surface Recovery Image download page (it is selected by model/serial).
    • Use a USB drive (Microsoft notes 32 GB is enough for any image; smaller may work depending on the download) and ensure it will be formatted as FAT32 for booting.
    • On the PC, open Create a recovery drive (search “recovery drive”), and follow the prompts to create the USB recovery drive (this erases the USB contents).
    Step 2: Boot the Surface Go 3 from the USB and wipe it
    • Power off the Surface.
    • Plug in the USB recovery drive (you may need a USB‑A to USB‑C adapter if your USB stick is USB‑A).
    • Press and hold Volume Down, then press and release Power.
    • When the Surface logo appears, release Volume Down to boot from USB.
    • Follow the on-screen recovery options to reinstall Windows and wipe the device back to factory state. Creating and using a USB recovery drive for Surface - Microsoft Support
    Note: This will delete everything on the Surface when you choose Remove everything / factory recovery.
    If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
    Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
