Visio 2021 gridlines don't match drawing when printing
Jerry Gaston 5 Reputation points
2026-01-24T22:50:49.8933333+00:00
I have grid lines turned on for my drawing. when I go to print my drawing the gridlines do not match what I see when I am editing my drawing. It looks like the horizontal gridlines match (some are solid lines some are dotted lines). The vertical lines are all solid but only 1 line where there should be 4.
printedprint1
drawingDrawing1
Microsoft 365 and Office | Visio | For home | Windows
    2026-01-25T12:12:37.8133333+00:00
    Dear @Jerry Gaston
    Good day! Welcome to Microsoft Q&A forum!
    Based on your description, I understand that you’re experiencing an issue in Visio 2021 where the gridlines displayed while editing the drawing do not align with the gridlines shown in the printed output, particularly with vertical gridlines appearing incorrect or missing compared to what you see on screen.
    I sincerely apologize for the inconvenience caused by this issue.
    Thank you for taking the time to share the screenshots and detailed observations regarding the gridlines in Visio.
    I’ve tested this behavior on my end using Visio 2021 with the same configuration (Fine grid enabled and Print gridlines turned on), and I’m seeing the same experience. The grid displayed on the drawing page does not exactly match what appears in Print Preview or in the final output.
    This is the grid in the drawing:
    This is the grid in the print preview:
    You could see that some gridlines, particularly finer vertical lines are simplified or missing compared to the on‑screen grid.
    My colleague also tested this on her device and she also had the same experience.
    To understand the situation better and provide you with the most suitable support, could you confirm the following information:
    • Were you able to print Visio drawing with the same correct gridlines before or this is the first time you tried printing it?
    Your confirmation would be very helpful!
    While Microsoft’s documentation does not explicitly state that printed gridlines will differ from the grid shown on the drawing page, the available guidance does describe gridlines as visual aids intended to help with alignment while editing, and it also notes that printing uses a separate rendering process that is influenced by printer and output settings. Based on this, and on consistent reproduction of the behavior during testing, the difference in grid appearance appears to be a current behavior rather than an issue with your file or configuration.
    These are the articles about this matter:
    Because this behavior is not clearly called out in current documentation, we would encourage sharing feedback directly with Microsoft so it can be reviewed by the Visio product team. This can be done from within Visio by going to File > Feedback, or through Microsoft’s Feedback Portal.
    Submitting feedback helps ensure scenarios like this are visible for potential future improvements.
    If enough users send feedback for the same idea, Microsoft may quickly consider adding this feature in the near future.
    Therefore, please kindly send the link to your feedback here so that other users with the same query could add their votes to your feedback.
    Note: As Microsoft Community moderators, please note that we are not involved in product design decisions and do not have direct access to the development roadmap, we want to assure you that your feedback has been acknowledged and is valued.
    Thank you for your kindness and understanding!
    If you have extra questions about this answer, please click "Comment".
  2. msPete 0 Reputation points
    2026-04-22T16:23:19.6666667+00:00
    Holy crap I just spent a day on a drawing that I was relying on being able to accurate print gridlines for... what joke!!!!!!!!!!!!!!!!!!!!!!
