Surface Pro 8 charging/battery issue (0% + blocked firmware)
Mia Grenmark 5 Reputation points
2026-01-20T05:32:22.56+00:00
Hi!
I need help troubleshooting a charging/battery issue on a Microsoft Surface Pro 8. The device is connected to power (both with the original charger and via USB-C PD charging), but Windows continues to show 0% battery and the battery does not charge. Several Surface/firmware updates fail because the system battery is too low, which seems to create a “catch-22”. The battery has not degraded from heavy use and the reports show that computer has been used very little.
1) Main symptoms
Windows shows 0% battery while indicating it is plugged in / on AC power.
  • The device runs on external power, but battery percentage stays at 0% and never increases. It turns off as soon as I plug out the power.
Windows Update lists Surface Driver Updates that cannot proceed and asks to connect/charge the device.
  • In Device Manager, several Surface components under Firmware have a yellow warning triangle.
In the device properties, the error message states that the firmware update failed due to power requirements and that the system battery is not sufficiently charged to update the firmware (Code 14 / requires restart shown as well).
2) What I believe is happening (catch-22)
Some Surface firmware/driver components require a minimum battery charge to install firmware updates safely. However, because the battery appears stuck at 0%, the required firmware updates never install, and the device remains in this state.
3) What I have already checked / results
A) Autopilot / enrollment checks (to rule out management issues)
I queried Windows registry Autopilot provisioning keys and also ran dsregcmd /status.
The output indicates the device is not Azure AD joined / not domain joined (AzureAdJoined: NO, DomainJoined: NO, EnterpriseJoined: NO; WorkplaceJoined: NO).
So this does not appear to be an enrollment/autopilot lock issue.
B) Battery report
I generated a Windows battery report with powercfg /batteryreport.
The report shows Design Capacity and Full Charge Capacity are the same, suggesting the battery has not degraded from heavy use (i.e., the device appears to have been used very little).
Despite that, it still stays at 0% when plugged in.
C) Charging attempts
Tested with the original Surface charger: still shows 0% (plugged in).
Tested USB-C charging using a thick USB-C cable and a USB-C charger: behavior is the same (0%, plugged in).
I do not see any change indicating actual charging (no increase in percentage, no progress).
D) Device Manager
  • Under Firmware, some items show a yellow warning and the status message indicates firmware update failure due to insufficient battery level.
  • In Device Manager, under Batteries, the only listed battery device is Surface Battery (there is no Microsoft AC Adapter and no Microsoft ACPI-Compliant Control Method Battery on this system). I selected Surface Battery → Uninstall device, then restarted Windows to let it reinstall the driver automatically, which it did. I also carried out a forced shutdown / hard restart by holding the power button for ~30 seconds before turning it back on. None of these steps changed the behavior (battery remains at 0% although connected to power).
Can it be a hardware issue (battery failure, charge circuit, port/PD controller, internal connector), or a firmware/driver issue that can be resolved through manual installation of Surface drivers/firmware, or a specific recovery procedure?
If needed, I can provide a full list of the Surface components showing warnings and the exact error codes/messages.
I'd be very grateful for any advice!
/Mia
    2026-01-20T05:33:09.6866667+00:00
    It sounds like you're experiencing a complex issue with your Surface Pro 8 where the battery is not charging despite being connected to power. Here are some troubleshooting steps and considerations:
    1. Check Power Supply and Connections: Ensure that both the original Surface charger and the USB-C charger are functioning properly. You might want to test them with another device to confirm they are providing power.
    2. Firmware and Driver Issues: Since you mentioned that several firmware components show a yellow warning in Device Manager and that updates fail due to insufficient battery, it could indicate a firmware issue. If possible, try to manually install the latest Surface firmware and drivers from the Microsoft website. This might require the device to be charged sufficiently, so if the battery is completely unresponsive, this step may not be feasible.
    3. Battery Hardware Check: Given that the battery is stuck at 0%, it could indeed be a hardware issue. This might involve the battery itself, the charging circuit, or internal connectors. If the device is still under warranty, consider reaching out to Microsoft support or visiting a service center for a hardware evaluation.
    4. Reset the Device: If you haven’t already, perform a hard reset by holding the power button for about 30 seconds. This can sometimes resolve temporary glitches.
    5. Check for External Factors: Ensure that there are no external factors affecting charging, such as dirt or debris in the charging port, which can impede the connection.
    6. Battery Report Analysis: Since your battery report indicates that the design capacity and full charge capacity are the same, it suggests that the battery has not degraded significantly. However, this does not rule out the possibility of a malfunctioning battery or charging circuit.
    If these steps do not resolve the issue, it may be necessary to consider professional repair options, especially if hardware failure is suspected.
