A family of Microsoft word processing software products for creating web, email, and print documents.
Hi @Hole, John,
Thank you for reaching out to us. I’d like to provide you with the following information:
Based on my test environment, the right-click action and switching between Linear and Professional formats can be performed as shown in the image below:
Version: 2510 (Build 19328.20266 Click-to-Run)
If you are unable to switch between these two formats, please check the following:
- The formula is not in Equation format
- If you are typing the formula as regular text, Word will not recognize it as an equation for conversion.
- Only formulas inserted via Insert → Equation or using Math syntax can be converted.
- Currently in Math AutoCorrect mode but not switched to Equation
- When you type a formula in the document without pressing Alt + = (to enter Equation mode), it remains as text.
- Word version or display mode is limited
- Some older versions or Compatibility Mode do not fully support this feature.
- Formula contains invalid characters
- If the formula includes special characters or incorrect syntax, Word will not be able to convert it.
And if you want formulas to always display in Professional format, please set it up as follows: Click Equation → Conversion → Automatically convert expressions to professional format.
I hope this information is helpful.
If you have any questions or need further assistance, please feel free to share them in the comments on this post so I can continue to support you.
I look forward to continuing the conversation.
