Dear @Janamatti, Priyanka,
Thank you for posting your question in the Microsoft Q&A forum.
We apologize for any inconvenience you may encounter when using our services/ products. Based on your description, kindly try these following steps:
Install all Windows and Surface driver/firmware updates
- Windows Update: Install all Quality and Optional updates, especially the ones labeled Surface in Driver updates.
- Settings > Windows Update > Check for updates
- Then View optional updates and install everything Surface‑related.
- Surface app health check: Open the Surface app > Device information to confirm drivers/firmware are current. If they are not, follow the Download drivers and firmware for Surface - Microsoft Support guidance.
- If you use a Surface Dock or USB4/Thunderbolt dock:
- Confirm your dock is compatible with your specific Surface Laptop model and update its dock firmware.
- See Use a Surface USB4 Dock for model compatibility and Surface Dock 2 overview for firmware management. Use a Surface USB4 Dock - Microsoft Support
Reinstall USB/USB4 controllers
- Navigate to Device Manager > Universal Serial Bus controllers and USB4™ Host Router (if present).
- Right‑click each USB Root Hub (USB 3.0/3.1) and USB4 controller > Uninstall device (do not delete driver files).
- Restart the laptop; Windows will re‑enumerate the controllers and ports.
Here is a reference: Fix USB-C problems in Windows - Microsoft Support
Run Surface Diagnostic Toolkit (SDT)
- SDT automates checks for port, power, and firmware problems and is Microsoft’s recommended step after you’re fully up to date. Fix common problems using the Surface app and Surface Diagnostic Toolkit - Microsoft Support
