HOW TO FIX NOAUDIO DEVICE INSTALLED ON Z140C
HLANIN 40 Reputation points
2025-12-21T05:45:01.4633333+00:00
WIFI ICON DOESNT DISPLAY OR SHOW ON Z140C AND NO INTERNET
AI answer
2025-12-21T05:46:17.33+00:00
To address the issue of "No Audio Device Installed" on your Z140C, you can follow these steps:
  1. Check Device Manager: Open Device Manager by right-clicking on the Start button and selecting it. Look for any devices listed under "Sound, video and game controllers". If you see a yellow exclamation mark next to any audio device, it indicates a driver issue.
  2. Update Drivers: If the audio device is listed but not functioning, try updating the driver. Right-click on the audio device and select "Update driver". You can choose to search automatically for updated driver software.
  3. Install Device-Specific Drivers: If the device-specific driver is not installed, you may need to download it from the manufacturer's website. Make sure to install the correct driver for your audio device.
  4. Check Windows Updates: Sometimes, installing the latest Windows updates can resolve driver issues. Go to Settings > Update & Security > Windows Update and check for updates.
  5. Restart the Computer: After making changes, restart your computer to ensure that any updates or installations take effect.
For the Wi-Fi icon not displaying and no internet connection, you can try the following:
  1. Network Troubleshooter: Go to Settings > Update & Security > Troubleshoot > Additional troubleshooters > Internet Connections. Run the troubleshooter to identify and fix network issues.
  2. Check Network Adapter: In Device Manager, check under "Network adapters" for any issues with the Wi-Fi adapter. If there are issues, try updating the driver or reinstalling it.
  3. Enable Wi-Fi: Ensure that Wi-Fi is enabled on your device. You can usually toggle Wi-Fi on and off using a function key (like F2) or through the Windows settings.
  4. Restart Router: If the device still cannot connect to the internet, try restarting your router to refresh the connection.
  5. Check Airplane Mode: Make sure that Airplane mode is turned off. You can check this in the Action Center or in Settings under Network & Internet.
If these steps do not resolve the issues, further investigation may be required, such as checking for hardware problems or consulting with the manufacturer.
2 additional answers
  1. HLANIN 40 Reputation points
    2025-12-21T05:48:22.71+00:00
    WIFI ICON DOES NOT SOW ON THE DISPLAY AND NO INTERNT
  2. Anwar Al'Sadat Abdulrahman 5 Reputation points
    2025-12-21T06:13:06.5966667+00:00
    Hi HLANIN,
    If I understand you correctly, you have a Mecer Z140C that WI-FI and Sound aren’t working? If yes, then it might be a drivers issue. What you would need is another computer that’s connected to internet.
    Visit:
    http://downloadcenter.mustek.co.za/Notebook/
    select the exact model of your Z140C. Download the drivers file for your Z140C. Copy it to the Z140C, extract it, install and restart the PC.
    THIS SOLUTION WILL WORK ONLY ON MECER Z140C
