Issues setting up out of box surface go 3 oops message
Omar Gallegos 0 Reputation points
2025-12-10T13:21:45.08+00:00
Hello! I’ve tried for 2 days to set up a second device using my same MS account (Hotmail). In the initial set up, when typing my MS email it prompts me to choose Face ID, security key, etc. The other option is a memory stick which I don’t have. And then the oops message appears every time.
I validated my MS account and have a password for it. I couldn’t set up offline since the surface go 3 (new device) detects WiFi connections and there’s no option to set up offline; I guess Windows 11 forces users to login this way for safety reasons.
I also installed a fresh version of Windows as AI suggested to no avail. I ended up using a gmail account and hotmail as secondary account. I can’t make MS the main account since it’s more convenient for me.
Any help would be appreciated.
Moved from: Community Center | Discuss the Q&A site | Site bug or problem
Surface | Surface Go | Install and update
  1. Ian-Ng 14,145 Reputation points Microsoft External Staff Moderator
    2025-12-12T17:12:56.2333333+00:00
    Hi @Omar Gallegos,
    Welcome to Microsoft Q&A forum.
    Thank you for your patience and for providing such detailed information regarding your experience setting up your new Surface Go 3.
    Based on your case, while attempting to log in with your primary Hotmail account, the system prompts for a security key you do not have and displays an "Oops" notification, preventing you from proceeding.
    This behavior typically occurs when the "Passwordless account" feature is enabled on your Microsoft account settings. When this feature is on, the initial setup process on a new device may look for authentication methods (like the Microsoft Authenticator app or a security key) that are not yet configured on the new hardware, rather than accepting a standard password.
    Since you currently have access to the desktop via the Gmail account, we can resolve this by adjusting the settings and switching the account type directly within Windows. Kindly follow the steps below:
    Step 1: Please try to verify your account settings
    • On a different device or your Surface browser, log in to your account via https://account.microsoft.com/security.
    • Locate the section labeled "Passwordless account".
    • If this is turned on, please turn it off temporarily. This ensures the system will accept your standard password during the switch.
    Step 2: Switch to your Hotmail Account
    1. On your Surface Go 3, open Settings > Accounts > Your info.
    2. Select the link that says "Sign in with a local account instead". Follow the prompts to create a temporary local user (this disconnects the Gmail association).
    3. Once the device signs you out and back in, return to Settings > Accounts > Your info.
    4. Select "Sign in with a Microsoft account instead".
    5. Enter your Hotmail address. Because we adjusted the settings in Step 1, it should now prompt for your password and allow the login to proceed normally.
    For your reference, here is the official Microsoft article regarding account switching:
    Please try these steps at your earliest convenience. If the behavior persists, please reply to this thread with the outcome so I can investigate further.
