Dissapearing battery icon for surface go 2
joeydooom 20 Reputation points
2025-12-08T07:35:29.0333333+00:00
my battery icon has decided to magically dissapear???
how do i fix it?
Surface | Surface Go | Power and battery
Alex-L 12,565 Reputation points Microsoft External Staff Moderator
2025-12-08T14:48:22.9933333+00:00
Hi joeydooom
Welcome to the Microsoft Q&A Forum!
Glad to hear the icon is back! That’s a good sign, it usually means the system tray settings and drivers are functioning again. Since you already have the icon, the main thing left is the percentage mismatch. We can work this out together and recalibrate the battery percentage to its correct capacity. Here's a few thing you can try:
  1. Update Surface Drivers and Firmware
  • Go to Start > Settings > Windows Update and click Check for updates.
  • Install all available updates, especially those labeled Surface Firmware or Driver updates.
  • Alternatively, download the latest drivers manually:
  1. Run Surface Diagnostic Toolkit (SDT)
  • Select Start , search for Surface Diagnostic Toolkit, then select it in the list of results. If it's not already installed, you can download it from Microsoft Store. Get the Surface Diagnostic Toolkit
  • Install and launch the tool.
  • Choose Battery and Power tests:
    • It will check battery health, charging behavior, and calibration.
    • Follow any recommendations provided by the tool (e.g., recalibration steps or firmware updates).
  1. Generate a Battery Health Report
  • Open Command Prompt as Administrator:
    • Press Win + X, select Command Prompt (Admin) or Windows Terminal (Admin).
  • Run:
      powercfg /batteryreport
    • This creates a file named battery-report.html in your user folder.
  • Open the report and review:
    • Design Capacity vs. Full Charge Capacity: If full charge is much lower, the battery is aging.
    • Cycle Count: High cycle count means wear.
    • Recent Usage: Check if the battery drains unusually fast.
  1. Calibrate the Battery
  • Fully charge your Surface to 100%.
  • Use it until it shuts down (0%).
  • Recharge to 100% without interruptions.
  • This helps Windows sync the actual battery capacity with its readings.
Hope this helps. Let me know how things go!
0 additional answers
