adapter connected but not charge my laptop
IT Support 20 Reputation points
2025-11-24T05:20:43.0933333+00:00
Laptop adapter ( charger ) connected but not charge my laptop
AI answer
2025-11-24T05:20:52.9333333+00:00
If your laptop adapter is connected but not charging your laptop, there are a few potential issues to consider:
  1. Charger Compatibility: Ensure that the charger you are using is the recommended charger for your laptop model. Using a charger that does not provide sufficient power can prevent charging.
  2. Connection Issues: Check the connection between the charger and the laptop. Make sure that the charger is securely plugged into both the wall outlet and the laptop. Inspect the charging port for any debris or damage that might affect the connection.
  3. Battery Health: If the battery is old or damaged, it may not hold a charge. In some cases, the laptop may not charge if it detects a fault with the battery.
  4. Power Settings: Sometimes, power settings in Windows can affect charging. Make sure that your laptop is not set to a power-saving mode that disables charging.
  5. Faulty Charger: The charger itself may be defective. If possible, test with a different charger to see if the issue persists.
  6. Windows Charging Management: Windows autonomously manages charging, and if there are any faults detected, it might stop charging automatically. Ensure that your system is functioning properly and that there are no alerts regarding battery or charging issues.
If none of these solutions work, consider reaching out to Microsoft Support for further assistance.
0 additional answers
