What is the hotkey for Strikethrough on Sticky Notes?
Accountant #97245 30 Reputation points
2025-11-21T17:42:09.0933333+00:00
CTRL + T no longer works as the hotkey for Strikethrough on Sticky Notes. All other hotkeys work for Bold, Italic, Underline... but not Strikethrough. Can someone please help me? Thanks!
Microsoft 365 and Office | Other
IGYQ 22,060 Reputation points Independent Advisor
2025-11-21T18:34:12.6433333+00:00
Hi!
Welcome to Microsoft Q&A forum.
Sticky Notes no longer supports a Strikethrough hotkey.
The only Workaround is:
  1. Type the text in Word or Notepad
  2. Apply Strikethrough there.
  3. Copy/paste into Sticky Notes. → Sticky Notes will display it correctly, but you still cannot edit it with native hotkeys.
1 additional answer
  1. Francisco Giordano-Silva 5 Reputation points
    2026-05-20T14:05:33.9966667+00:00
    I'm as baffled as the user!
    So let us get this straight. This is an application that mimics post-it notes. Post-it notes are also used very often as to-do lists. I'm sure Microsoft is aware of that: people use Sticky Notes as to-do lists, quick scribble. I don't want to use paper. I want to be more ecofriendly, jolt it down, type it quickly on a sticky note.
    If there's any place where strikethrough is important, it would be here. Why remove the hotkey? It's nonsensical. It's not even that we are asking for a feature addition. Why was it removed? Probably the style that's applied the most and you've decide to take it the hotkey off. Now im having to use my mouse everytime this is required.
    Terrible design choice.
