Text verification does not work to sign in
Prenissa Sookdiyal 0 Reputation points
2025-11-17T17:56:39.8933333+00:00
I am attempting to sign into Microsoft 365 admin Centre to update details for the Minecraft education license but the text verification will not work, nor are any other verifications methods available. I am the only admin. Can the phone block be removed?
Error Code: 399287
Request Id: remove PII
Correlation Id: remove PII
Timestamp: remove PII
Microsoft 365 and Office | Subscription, account, billing | For education | iOS
    2025-11-17T17:56:57.6133333+00:00
    If you're experiencing issues with text verification not working for signing into Microsoft 365, there are several troubleshooting steps you can take:
    1. Check Phone Number: Ensure that the phone number registered in your user account settings is correct. You can do this by accessing your account settings if you have alternative verification methods set up.
    2. Blocked Sign-In: Since you are the only admin, you should check if your account is blocked from signing in. You can ask another global admin (if available) to verify this by checking the Block sign in option in your user profile settings in the Microsoft Entra admin center.
    3. Limitations on Verification Attempts: If you've made multiple attempts to verify your account in a short period, Microsoft may temporarily limit further attempts. In this case, waiting a few minutes before trying again might help.
    4. Alternative Verification Methods: If text verification is not working, consider using other available methods such as the Microsoft Authenticator app or verification codes if you have them set up.
    5. Contact Support: If the above steps do not resolve the issue, you may need to contact Microsoft support for further assistance, especially since you have an error code (399287) that can help them diagnose the problem.
    If you find that your account is indeed blocked, you will need to have it unblocked by a global admin.
    2025-11-17T21:23:00.9266667+00:00
    Hi @Prenissa Sookdiyal,
    Thank you for reaching out to Microsoft Q&A forum.
    The error code 399287 and the inability to use text verification (with no other MFA options available) usually means your account is locked behind Multi-Factor Authentication (MFA) and the configured method is either broken or inaccessible. Since you’re the only admin, this can block access to the Microsoft 365 Admin Center.
    If you are the sole Global Administrator on the tenant, please follow the steps outlined below to proceed with account recovery and regain access.
    Option 1: Contact Microsoft Data Protection Support by Phone (Primary Method)
    To regain access to your admin account as you can't access the Admin Portal, you can try reaching out to our Global Customer Service phone to raise a request for resetting your authentication method here: Customer service phone numbers - Microsoft Support. During the call, request to speak to an agent, and share with them every detail related to your query and also mention that you are the only admin lost access to your account. This should allow you to contact the appropriate team so you can solve this incident as soon as possible.
    Here are some tips and an example of a prompt to help you navigate the IVR more effectively:
    In some countries, it is an automated conversation like:
    IVR: What kind of problem are you concerned about?
    You: Authenticator.
    IVR: What kind of product do you use?
    You: Office 365 for business.
    IVR confirmation: education or company account?
    You: For companies
    IVR: Are you an administrator?
    You: Yes.
    IVR: Do you have another administrator in your organization?
    You: No.
    IVR: Do you need a... Service request?
    You: Yes. I need to create a ticket. Please send me direct to the Data Protection Team.
    Option 2: Create a Temporary Account (Trial Tenant) to Submit a Support Ticket (Alternative Method)
    If you still cannot reach to a live agent, there is still a workaround, you might consider registering for a new tenant by signing up for a trial subscription via this link Microsoft 365 Business Plans and Pricing | Microsoft 365. This would allow you to create a new tenant following the prompts provided. Once set up, you can access the admin console of the new tenant and submit a support ticket requesting to speak with the Data Protection team on behalf of your previous tenant.
    Please note that forum moderators do not have access to user account settings and cannot assist with logging in, resetting passwords, or changing access rights. While we do not have access to internal systems or administrative tools required to resolve account-specific or backend-related issues but we’ll continue doing our best to support you within the scope of our responsibilities.
    I hope this helps you regain access to your account quickly. I'm glad to assist and truly hope the information provided has been useful. Please feel free to reach out anytime if you need further assistance.
    If you find my post helpful, kindly consider marking it as the accepted answer. Doing so can assist others in the community who may have similar questions in finding solutions more quickly.
    Thank you for your kindness and contributions to the forum.
