Hardware issue Battery is not charging
Mohammed Tabraiz 0 Reputation points
2025-10-30T11:29:05.1766667+00:00
Hi Team,
We are facing an issue with the Surface Hub — the battery is not charging and is showing an orange blinking light. The battery appears to be completely drained.
Please find the attached log files and picture for your reference.
Kindly look into this issue and advise on the next steps.
Surface | Surface Go | Power and battery
  1. S.Sengupta 32,351 Reputation points MVP Volunteer Moderator
    2025-10-31T17:07:02.15+00:00
    The Event Viewer shows there is runtime fluctuations — from “insufficient” to “sufficient.”The last image shows Battery Charge: 5.0% → which is critically low charge. This explains the “Insufficient Runtime Available” events in your log.
    Reconnect to mains power and let the UPS charge fully
    Now run a self-test in PowerChute.
    If “Runtime Remaining” stays at 0 or fluctuates abnormally — the battery needs replacement.
    See:
    Surface battery won’t charge or Surface won’t run on battery
