The built-in camera of my HP laptop running Windows 11 Home stopped working
Debra Morgan 20 Reputation points
2025-10-04T23:00:29.91+00:00
I use my built-in camera at least once a week if not more. Last week, it suddenly wouldn't turn on despite allowing the permissions. I have checked the drivers and they are up-to-date and permissions are allowed. I just installed an update this morning (2025-09 Cumulative Update for .NET Framework 3.5 and 4.8.1 for Windows 11, version 25H2 for x64 (KB5066613)) and another on the 2nd (Windows 11, version 25H2). I noticed the issue one week ago on 9-27-25. There is no button or switch to turn the camera on/off. This is the limit of my computer knowledge. I really need the camera to work since I use it weekly for virtual appointments.
Please help me!
John DeV 170.3K Reputation points Independent Advisor
2025-10-04T23:34:31.26+00:00
Hi, good day!
Are you getting any camera errors?
Please try the following methods below.
  • Some laptops have a privacy switch or a camera shutter key that can be used to turn off your webcam and prevent it from being used.
Camera Privacy Switch located at the right side of the laptop
Camera Shutter Key located on the keyboard
Please try to press FN+F6 or CTRL+F8, F10. or try other F key combinations.
  • Check your antivirus software
In your antivirus software settings, look for settings that block access to your camera or permission to use your webcam. For help, visit your antivirus software company’s website.
  • Run the Hardware and Devices troubleshooter Press Start then search command prompt
Right click then Run as administrator
Please type the command below then press Enter
msdt.exe -id DeviceDiagnostic
Run the troubleshooter
Restart your computer
If the issue persists, what is the exact model of your HP laptop?
Press Windows key+R to open Run then type: msinfo32
Press Enter
Please take a screenshot of the System Information window and post it in your next response. Note: Don't include any personal information or sensitive data.
I look forward to receiving your update and I'm willing to collaborate with you till we resolve the issue. Do keep me informed by clicking "Add comment" below.
0 additional answers
