Personal Vault name not allowed
Ayden Kahn 80 Reputation points
2025-09-12T15:12:03.1533333+00:00
Screenshot 2025-09-12 100915.pngHello, I am have a problem with my personal vault, it keeps telling me that the name is not allowed but it just says "Personal Vault" so im confused why its not allowed, it wont sync my folders until I fix it pleas help.
Microsoft 365 and Office | OneDrive | Other | Windows
2025-09-12T16:15:18.9466667+00:00
Hi Ayden Kahn,
Thanks for reaching out. I had a look at your screenshot, and the issue seems to be with the folder name "Personal Vault". OneDrive actually reserves that name for its secure storage feature, so using it for a regular folder or shortcut can cause sync errors like the one you're seeing: "This item name or type isn't allowed."
To fix it, just rename the folder to something else maybe something like "Secure Files", "Vault Folder", or "PrivateDocs". Once you do that, OneDrive should start syncing again without any problems.
Let me know if renaming the folder works for you or if you run into anything else, I’m happy to help!
Best,
Carl
0 additional answers
