Wake-on-Power for Surface Go 3 running Windows 11 Enterprise
Sherry 0 Reputation points
2025-08-07T02:41:08.6133333+00:00
I would like to enable the Wake-on-Power feature on a Surface Go 3 running Windows 11 Enterprise. However, the feature appears to be unavailable in the Surface UEFI configurator after installing the Surface IT Toolkit, and it is not functioning through Surface Enterprise Management Mode. Is the Wake-on-Power feature no longer supported on the Surface Go 3?
Surface | Surface Go | Power and battery
    2025-08-07T13:40:00.22+00:00
    Hi Sherry,
    Wake-on-Power feature is still available on the Surface Go 3, but it's only supported on commercial models typically those sold through Surface for Business and running Windows 10/11 Pro or Enterprise.
    To check if your Surface Go 3 is a commercial SKU, follow these steps:
    1. Press Windows + R to open the Run dialog.
    2. Type msinfo32 and hit Enter.
    3. In the System Information window, look for the entry labeled System SKU.
    If it says something like:
    Surface_Go_3_1926_Commercial - You have a commercial SKU.
    Surface_Go_3_1926.revise - This is a consumer SKU, and Wake-on-Power won’t be supported
    Hope this helps.
    Best,
    Jeric
