Syncing issues with OneDrive shared folders
2025-02-24T11:49:46+00:00
I have suddenly lost the sync function to 2 important shared folders (ones shared with other people) My other folders and files (not shared) are fine. How can I fix it? For some reason, the folders have been sent to my recycle bin, but I cannot restore them.
Microsoft 365 and Office | OneDrive | Other | Other
    2025-03-18T03:31:00+00:00
    I am having the same issue and It is driving me crazy. When will this be fixed?
    2025-03-18T06:31:58+00:00
    Somehow this problem went away. I can now sync shared folder. All previous sync disappeared and I need re-select what files to sync. I didn't do anything actively to fix this problem. But I do have auto-update enabled for all O365 apps.
    Good luck.
    2025-03-20T14:50:12+00:00
    For those who can sync shared folders again. What is your OneDrive version?
    Im on this version, and I still cannot sync the shared folders from another account.
    OneDrive version: Build 25.041.0303.0002 (64-bit)
    2025-03-20T15:00:10+00:00
    Fixes if you upgrade Onedrive to the latest version on the sharing computer
    2025-03-20T15:25:55+00:00
    But the OneDrive from where I get the shared folder is only accessed from the web app. So there's no OneDrive installed on any computer for the sharing OneDrive folder. It's an account I own.
