Error code 30015-45 (193) and 0-2031-(17002)
2025-02-26T15:26:30+00:00
I tried to instal office 2024 on my laptop. But there are two messages popping up:
"Something went wrong.
Sorry we ran in to a problem.
Error code 30015-45 (193)"
after closing the message, a second one pops up:
"Could't install
We're sorry, we had a problem installing your Microsoft 365 and Office program(s).
Is your internet connection working? Do you have enough free space on your main hard drive?
Please try installing again after you've checked the above.
Error Code: 0-2031-(17002)"
I can confirm stable internet connection and free space on hd (170GB). Is there anyone who could give me a hint, which steps to proceed and how to solve the two error codes?
Thanks and regards
    2025-03-12T11:05:40+00:00
    can you share the file to me?
    i have the same error, i tried to uninstall microsoft 365 and got the same error
    2025-03-11T14:35:33+00:00
    Can you share this file with me?
    2025-02-27T06:06:54+00:00
    Hi, Yann_sparrowhawk
    Thank you for using Microsoft products and posting them to the community.
    This is a tricky issue, these two error codes indicate a misplaced or missing system configuration file.
    You can check if you have a third-party firewall turned on, if so, turn it off first, and then if your Windows is the latest update, if not, change your Windows to the latest version.
    If the above options can't solve the problem, please try the following steps:
    1. Please open the file I shared with you in private messages and save it as a new file on your desktop.
    2. Change the file extension from .txt to .cmd, then right-click and run it as an administrator. (If you can't see the file extension, press Windows + E to open File Explorer, go to Options > View, and uncheck "Hide extensions for known file types" in the advanced settings.)
    3. After running the file, an option will appear (yes or no); type y (yes) and press Enter.
    4. At this point, four options will appear; enter 2 and press Enter. Sometimes, you may need to press any key to continue (a prompt will appear).
    5. After option 2 has completed, enter 3 and press Enter. Again, you may need to press any key to continue (a prompt will appear).
    6. After option 3 has completed, enter 4 and press Enter; the command will close automatically.
    7. Re-download Office.
    Check out the private message here:
    Please try the above steps first, if none of them work, then you may need to do an override installation or reinstallation step.
    Looking forward to your reply.
    Best wishes
    Aiden.C - MSFT |Microsoft Community Support Specialist
