A family of Microsoft products that enable users to capture, organize, and reuse notes electronically.
Appears to be a broken link.
Please upvote this request:
https://feedbackportal.microsoft.com/feedback/idea/0fae6e48-04d8-ef11-95f5-6045bdb154fd
Today, I turned on Onenote, and it notified me that it had Copilot update.
Now, every time I click in Onenote, it shows this annoying Copilot icon next to cursor:
How do I remove it?
Thank you.
Removing copilot from the ribbon, disabling optional experiences in account privacy, and then following this worked for me to get rid of the inline Copilot icon. Unfortunately that doesn't return the ability to double-click next to a heading to expand/collapse it like OneNote did last week. So now all of my OneNote pages are extremely long - I use headings/outline structure EXTENSIVELY. Now each page is not much better than a watered down Word document in terms of navigation.
Start > Menu (all) > look for Copilot and hover over it > right mouse click > Uninstall > DONE or Settings > Apps >Installed Aps > Copilot > Uninstall > DONE
Another example of a corp AI forced onto clients and meant to scrape data.
If I find that any of my copywrited work is being used, I will be reporting it to the proper authorities as intellectual property theft.
First Google, now MS.
If this keeps up, I might go analog/paper.
Immoral, unethical and disgusting.
MS should be ashamed.
How does Copilot use data?
I think their PMs and devs have become accustomed to empty threats on message boards over the years, but in this case they might “find out“ as they say.
It appears someone has locked that feedback portal post? I get this error code
An error occurred and we're working on a solution. Sorry for the inconvenience. Error code: 400Tracking ID: 5912a244-f194-4c59-a4ae-cce6724ad3dc
But the page tab also just says "you have been blocked"
