OneDrive Personal Vault cannot unlock, error code 0x8004db90
2024-08-13T00:33:24+00:00
I haven't been able to access my OneDrive Personal Vault in the past few days. I've tried multiple ways (PC, iOS app, webpage) but none works -
  • on the iOS app, it prompted me to setup personal vault even though I've done the setup a long time ago. After completing authentication, the app popped up with "Unable to complete Personal Vault setup, please try again in a few minutes". I tried removing the app and started fresh and that didn't help.
  • on webpage, after authentication, it popped up saying "There was a problem unlocking your Personal Vault". I tried both Edge and Chrome and got the same results.
  • on PC, onedrive can't unlock my personal vault, and popped up with error code 0x8004db90. I tried unlinking onedrive and relinking it and that didn't help.
Overall this feels like an authentication issue but somehow only affects personal vault access.. If anyone has any suggestions I'd greatly appreciate it!
  1. Deleted
  2. Deleted
    2024-12-09T17:34:05+00:00
    I have seen the exact same problem, but the error code was 0x8004db94 and not 0x8004db90
    In my case, I managed to fix this issue following these steps given by a Tier-3 Microsoft Engineer:
    Some users reported they didn't see the "Restore files" as the screenshot at the end of these steps, so make the backup as below:
    Access your files on the Onedrive web page (https://onedrive.live.com/), then go to "My Files" --> open the Personal Vault folder and download your files before
    1) Exit OneDrive
    2) Open Command prompt from start menu and paste the following command and hit enter:
    REG DELETE HKCU\Software\Microsoft\OneDrive\Accounts\Personal /v VaultBackupGuid
    Its ok if this returns ERROR: The system was unable to find the specified registry key or value. Just continue following the next steps.
    3) Open Credential Manager from start menu
    4) Select the Windows Credential tab
    5) Find the credential named "Microsoft OneDrive Generic Data - Personal Vault VHD info" and click Remove.
    6) Restart OneDrive and try to unlock the Vault
    Then, when you log-in again if do you see this message below, click on RESTORE, otherwise you will lost your files from the Personal Vault.
    These steps above worked for people talking aobut this issue in another post:
    https://answers.microsoft.com/en-us/msoffice/forum/all/onedrive-error-0x8004db94/44362d63-da4b-4831-81b7-bfd71aaaeee4
    Follow these steps by your own risk because I cannot guarantee it will work to everyone :-)
    2024-12-11T15:46:03+00:00
    Thank you, Renato!
    This solution worked for me.
    However, I did not get a prompt for Restoring Files. And the contents of the Personal Vault are gone.
    Luckily, I had a back of the contents in the Personal Vault.
