Power Automate Copy file no longer works - Copy SharePoint Home.aspx to New SharePoint site
2024-09-19T10:30:35+00:00
Need help:
Power Automate Copy file not working since 18.9.2024 - copy SharePoint Home.aspx to New SharePoint site, error: Invalid number value. A number field contains invalid data. Please check the value and try again. CallStack -- at Microsoft.SharePoint.SPGlobal.HandleComException(COMException comEx) at Microsoft.SharePoint.Library.SPRequest.SetGhostedFile(String setupPath, Byte setupPathVersion, Int32 iVersion, Guid& pguidListId, Guid& pguidDocId, Int32 lDoclibRowId, Int32 iAuthorId, String authorLogin, String serverRelativeUrl, String targetUrlWebRelative, Boolean isInDocLib, Boolean isMigration, Boolean isPublishing Object varProperties, Int64 PutFileOpt) at Microsoft.SharePoint.Deployment.FileSerializer.SetGhostedFile(Object fileOrListItem, SPLoggerObject loggerObject, SPWeb web, Guid existId, SPResourcePath fileUrl, SerializationInfoHelper infoHelper, SerializationInfoHelper infoHelperListitem, Boolean fileExistsInDb, Nullable`1 isLastVersion, StreamingContext context) clientRequestId: 1f3421bf-23fb-48aa-887a-e*** serviceRequestId: 77bf51a1-d04f-9****
Microsoft 365 and Office | SharePoint | For business | Windows
    2024-09-23T11:25:31+00:00
    Hi, Any updates on this issue? It's affecting several of our workflows. Does anyone know if Microsoft has recorded an outage yet? I've already raised a ticket but haven't received a response, and the issue is still ongoing.
    2024-09-23T16:03:35+00:00
    Same issue for me - live Flows in client tenants now failing. Has anyone found any solution please or are we all waiting for Microsoft to acknowledge the issue?
    2024-09-23T18:14:33+00:00
    2024-09-23T18:38:04+00:00
    This Article might help for clarification:
    Important changes (deprecations) coming in Power Platform - Power Platform | Microsoft Learn
    What's the link with the issue raised in this thread?
    2024-09-23T20:56:42+00:00
    Exact same issue as everyone above. Copy File is now failing with no changes. Weekly flow ran on 9/20 and failed when the prior week's succeeded. Same error message as OP
