Power Automate Copy file no longer works - Copy SharePoint Home.aspx to New SharePoint site
2024-09-19T10:30:35+00:00
Need help:
Power Automate Copy file not working since 18.9.2024 - copy SharePoint Home.aspx to New SharePoint site, error: Invalid number value. A number field contains invalid data. Please check the value and try again. CallStack -- at Microsoft.SharePoint.SPGlobal.HandleComException(COMException comEx) at Microsoft.SharePoint.Library.SPRequest.SetGhostedFile(String setupPath, Byte setupPathVersion, Int32 iVersion, Guid& pguidListId, Guid& pguidDocId, Int32 lDoclibRowId, Int32 iAuthorId, String authorLogin, String serverRelativeUrl, String targetUrlWebRelative, Boolean isInDocLib, Boolean isMigration, Boolean isPublishing Object varProperties, Int64 PutFileOpt) at Microsoft.SharePoint.Deployment.FileSerializer.SetGhostedFile(Object fileOrListItem, SPLoggerObject loggerObject, SPWeb web, Guid existId, SPResourcePath fileUrl, SerializationInfoHelper infoHelper, SerializationInfoHelper infoHelperListitem, Boolean fileExistsInDb, Nullable`1 isLastVersion, StreamingContext context) clientRequestId: 1f3421bf-23fb-48aa-887a-e*** serviceRequestId: 77bf51a1-d04f-9****
Microsoft 365 and Office | SharePoint | For business | Windows
    2024-09-25T14:44:59+00:00
    As of today 9/25/24 10:30 AM EDT my flow works again.
    I went into the 28 day run history and resubmitted the failed job (so no changes and no input from me) and it is successful today. My Automation is very simple, and follows the steps listed here Copy SharePoint page between sites with Power Automate (tomriha.com)
    1. Manual Trigger,
    2. Get file properties,
    3. Copy File.
    If it were run as usual from the Source site, the only input is to ask for the link to the site, and then it copies the file to the Site Pages directory on that site.
    Glad things appear to be working again, but I'll monitor this thread for any other updates.
    2024-09-26T01:26:03+00:00
    Hi Bart.
    thank you for telling the workaround.
    I tried its workaround and confirm to success, though.
    The news which i posted and copied doesn't diplay on news Web Parts in the destination site, being not published status.
    2024-10-07T07:44:20+00:00
    This is working now. Thank you everyone for highlighting this issue.
    Cheers
