how to fix error 29 in office 365
2024-07-03T14:26:11+00:00
Cannot reactivate office 365 and get error code 29 when updating license. I've uninstalled and reinstalled all the programs, and followed all the online steps suggested by Microsoft. I've tried the Office 365 self-repair tool, and re-logged into my Microsoft account. Nothing works.
2024-07-04T21:26:02+00:00
For a simpler fix, you can try these:
Close all Office apps first.
  1. Go to File Explorer > View > Show > Hidden items.
  2. Navigate to C:\Users\*your username*\AppData\Local\Microsoft
  3. Delete IdentityCache folder
  4. On the same page, look for OneAuth folder and open it.
  5. Delete the contents of OneAuth folder such as "accounts" and "blobs"
  6. Launch any Office apps and sign in your account. You might need to relaunch the app multiple times until the error is gone.
Let me know if it works for you!
Kind regards,
63 additional answers
  1. Stefan Blom 352.4K Reputation points MVP Volunteer Moderator
    2024-09-10T20:17:07+00:00
    I cannot figure this out
    Dan,
    Try the solution suggested by PeanutKimKim earlier in this long thread.
    2024-09-10T21:37:15+00:00
    YOU ARE THE BEST!!!!!!!
    I tried for 3 hours different ways to fix it until I saw your answer and it work!!
    Thank you so much!!!!!
    2024-09-11T18:28:51+00:00
    Great! Thank you!
    2024-09-13T00:26:04+00:00
    Kind regards,
    OMG! Thank you so much. I have been going at it for so many hours at this point. Finally a good solution that actually worked. Really appreciate it! Life saver.
