Please help me disable personal vault I didn't want it and I can't get rid of it.
2024-04-01T00:05:17+00:00
    2024-07-01T00:44:44+00:00
    Same here, I can't find the option to disable it. Personal Vault is a complete failure and keeps cauing sync problems.
    2024-07-03T12:26:13+00:00
    Running Win 11 Pro 64 bit version 23H2 build 22631.3737
    Unfortunately your instructions are useless, it cant be disabled under Win 11 Pro 64 bit version 23H2 build 22631.3737 or Android 13, also OneDrive on Android 13 doesn't have a hamburger menu
    The update accompanying Win 11 Pro build 22631.3737 did not mention anywhere that it would lock down your entire OneDrive folder, It made it sound like something totally optional you could set up separately. The only relevant setting under Onedrive settings is changing the period it locks after to 4 hours.
    2024-08-08T17:56:37+00:00
    i.e. I get no "disable personal vault option", only the option to change "Lock the personal vault after".
    Microsoft has a real problem that they keep tinkering with user interfaces so you come to a place like this for help and the answers frequently have no bearing on what MY user interface looks like.
    2024-08-11T00:51:57+00:00
    Has this been sorted? I also have NO DISABLE OPTIONS... and my files have stopped syncing. I am waiting for important files to move and this is a shocking scenario.
    2024-08-11T07:42:37+00:00
    Hi mate, it was not sorted at all. Now I just had to end the task of Onedrive to make my computer working. Otherwise, it will just freeze my explorer.
