Sway not working
2024-06-28T13:12:39+00:00
Sway is not uploading or downloading anything today. Also I'm being blocked from support contact for some reason this afternoon whereas this morning I was able to contact an advisor. I use Sway a lot on my community homepage so this is very inconvenient, as is not knowing where the problem is. Hello Mucrosoft? Anybody there?
Microsoft 365 and Office | Sway | For home
    2024-06-30T08:38:46+00:00
    The links to mySways do not work anymore. I noticed the security certificate for sway-cdn.com issued by Microsoft Azure expired on the 28/06. I suspect this is not a coincidence, and that is why browsers are blocking it. I'd like to have an answer,
    2024-06-30T10:09:58+00:00
    My Sway is not working. I've reset the settings only to find that doesn't work either. The view count is also going ridiculous. Please can you sort this out. I now need to contact the people I have shared the link with to give them the new one...only to find that I didn't actually need to reset the link in the first place!
    2024-06-30T10:24:56+00:00
    Exactly!! The view count has gone mad, as it clocks on several times with each attempt, but the connection doesn't work at the viewer end....
    2024-06-30T10:38:28+00:00
    That's it. I've got someone clicking on two different links of the same story and I can say which one she is clicking on because the view count goes up by hundreds.
  5. Deleted
