Processes in Microsoft 365 for setting up Office apps, redeeming product keys, and activating licenses.
I have MS Office 2018 not Office 365. How do I uninstall the Aptos font ans change the default font to Arial
Tony,
There is no single location in which you can change the font for all Office applications.
In Excel for Windows, you can change the default font for future workbooks via File > Options > General.
In Word for Windows, select the font you want in the Font dialog box (Ctrl+D) and click Set as Default (see the screen shot below). When prompted, choose "all documents based on the <template name> template." In most cases, you want to change the font for the blank document template, which is called Normal.dotm. The modification applies to future documents based on the template. Later, if/when you are prompted to change the template, choose to do so.
