A cloud-based task management app from Microsoft that helps users organize and manage daily tasks across devices.
Hello Mitchell,
- To sort Planner tasks within buckets by due date automatically, you need to use the Group by option in the upper right corner of the board view.
- Select Due date from the drop-down menu and the tasks will be grouped into buckets based on their due dates, such as Today, Tomorrow, Next week, etc.
- You can still see the original bucket names under each task card, and you can change them as needed.
- When you add a new task, it will automatically go to the appropriate bucket based on its due date, and you can adjust it later if you want.
- This way, you can keep the Kaban-style board format and have each column sorted by due date without manually dragging and dropping the tasks.
Hope this helps!
Fathia
