How can I sort Planner tasks within buckets by due date automatically as I add them?
2023-08-14T15:13:58+00:00
I use a Kaban-style board sorted into buckets for each project. Frustratingly, I cannot figure out how to sort the tasks within a bucket by due date automatically. Currently, if I want to see the most urgent items at the top and least urgent at the bottom, I need to manually drag the task down... which does not scroll down well, so I often need to drag & drop, drag & drop, drag & drop... until it arrives where I need it.
How could I keep this same Kaban-style board format (not list, grid, or schedule view) and have each column sorted by due date, even when I add a new task in?
Microsoft 365 and Office | Microsoft To Do | For business
  1. Deleted
    2025-03-04T10:18:04+00:00
    Hi Richard, did you find an alternative yet? I'm more than ready to make the switch to another platform and transfer everything... I'm fed up with this. Thanks in advance!
    2025-02-04T20:40:32+00:00
    I swear there used to be a way to do this, before the Planner-Tasks-Teams-Everything merger.
    It is a bit ludicrous to have a planner application not allow sorting by due date while staying in buckets. Grouping by due date is not at all helpful, having the bucket as a tag is just not at ALL what I'm looking for in functionality.
    2025-01-22T23:26:31+00:00
    It is brutally inadequate but you can drag/drop the items within the bucket to manually sort them by date.
    I am using that to limp along until this gets fixed.
