OneNote 365 Not Displaying TABS LAYOUT > VERTICAL TABS Option
2023-03-22T23:02:53+00:00
Hi Support,
I installed the latest version of Office 365 / Microsoft 365 and while searching online says to go to VIEW > TABS LAYOUT > VERTICAL TABS to make OneNote display the tabs vertical as opposed to horizontal; however, when I click on VIEW, I don't see this option and only see the follow image below.
I tried to go to FILE > OPTIONS > DISPLAY to see if I could customize the RIBBON and don't see this option.
Any advice is very much appreciated.
Thank you very much,
Sonny
Microsoft 365 and Office | OneNote | For business | Windows
2023-03-23T01:46:28+00:00
Dear Sonny,
It seems that you are talking about the feature mentioned in New Layout Options for OneNote on Windows are coming soon (microsoft.com). I'm afraid that the feature hasn't been released to all version number of the OneNote application. I suggest you keep close eyes on the updates of the OneNote application and wait for the feature in your environment.
As a workaround, you can click on the notebook tab>click on Pin Notebook Pane to Side currently.
Thanks for your understanding and have a nice day!
Sincerely,
Cliff | Microsoft Community Moderator
53 additional answers
    2023-07-10T17:45:00+00:00
    If you have Office then you should have OneNote (the OneNote you need) and OneNote for Windows 10.
    OneNote you can recognize by having a File menu.
    Bernd
    2023-07-16T22:47:53+00:00
    It was always there before! Why was it disabled?
    2023-07-18T05:57:35+00:00
    Dear Donald,
    About "It was always there before! Why was it disabled?", what issue happens in your environment? Could you provide more detailed information about the issue symptoms for our reference?
    If you are experiencing a different issue, welcome to post a new thread on our forum at your convenience.
    Thanks for your effort and time!
    Sincerely,
    2023-07-24T18:32:39+00:00
    Thank you for the workaround.
    Is there an ETA for this feature?
    In the linked New Layout Options for OneNote on Windows are coming soon (microsoft.com). I noticed some comments that said this feature was showing in V2305 I am running V2306 and I do not see the vertical tabs feature.
    Based on the comments in this thread it sounds like this feature might have been released and then rolled back. Is that correct?
