Heartbeat Exe not working
2021-03-04T00:22:13+00:00
Faulting application name: OLicenseHeartbeat.exe, version: 16.0.13806.20000, time stamp: 0x601e33f7
Faulting module name: KERNELBASE.dll, version: 10.0.19041.804, time stamp: 0x0e9c5eae
Exception code: 0xc06d007e
Fault offset: 0x000000000002d759
Faulting process ID: 0x11f0
Faulting application start time: 0x01d71034c99d2236
Faulting application path: C:\Program Files\Common Files\Microsoft Shared\Office16\OLicenseHeartbeat.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report ID: 1461e9dc-6097-****-****-b4406ef205e1
Faulting package full name:
Faulting package-relative application ID:
Hya all here is the information about this issue i have with the Office heartbeat Exe i would like to know 2 things what it does and why has it stopped woprking
2021-03-10T15:40:48+00:00
16.0.13801.20182 is the problem - either upgrade to 16.0.13801.20288 or downgrade as I wrote below and have been working for 3 days without the error.
2021-03-10T15:36:05+00:00
This has NOTHING to do with Windows updates.
This is caused by the "Office 16 Click-to-Run Licensing Component" and its latest update to version 16.0.13801.20182 or later.
Rolling back to version 16.0.13530.20528 (aka "Version 2012") will solve the problem.
See below I have been error free since the downgrade after 3/7/21
49 additional answers
    2021-03-07T09:45:42+00:00
    same error here too in last 2/3 days
    2021-03-07T20:22:47+00:00
    I am seeing the same issue on two different PCs, one running Win 10 Pro 20H2 OS Build 19042,804 and the other running Win 10 Pro 1909 OS Build 18363.1379. Office 365 subscriptions are up to date on both computers and seem to run fine. This started on or around February 6 for me.
    Likely the result of a recent update that appears to be affecting a lot of folks so hopefully it will be corrected soon.
    2021-03-08T00:15:31+00:00
    Ya I am receiving the same errors for the last several days. On 3/4 it appears that some Office updates or reconfigurations were pushed by Microsoft and they were completed successfully, but every day after that overnight (likely when my system either checks for updates or does maintenance) it lists this error for the Heartbeat - appears to me to be a Microsoft-caused issue due to poor QA.
    I'm running Office 2019 if it matters.
