Heartbeat Exe not working
2021-03-04T00:22:13+00:00
Faulting application name: OLicenseHeartbeat.exe, version: 16.0.13806.20000, time stamp: 0x601e33f7
Faulting module name: KERNELBASE.dll, version: 10.0.19041.804, time stamp: 0x0e9c5eae
Exception code: 0xc06d007e
Fault offset: 0x000000000002d759
Faulting process ID: 0x11f0
Faulting application start time: 0x01d71034c99d2236
Faulting application path: C:\Program Files\Common Files\Microsoft Shared\Office16\OLicenseHeartbeat.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report ID: 1461e9dc-6097-****-****-b4406ef205e1
Faulting package full name:
Faulting package-relative application ID:
Hya all here is the information about this issue i have with the Office heartbeat Exe i would like to know 2 things what it does and why has it stopped woprking
2021-03-10T15:40:48+00:00
16.0.13801.20182 is the problem - either upgrade to 16.0.13801.20288 or downgrade as I wrote below and have been working for 3 days without the error.
2021-03-10T15:36:05+00:00
This has NOTHING to do with Windows updates.
This is caused by the "Office 16 Click-to-Run Licensing Component" and its latest update to version 16.0.13801.20182 or later.
Rolling back to version 16.0.13530.20528 (aka "Version 2012") will solve the problem.
See below I have been error free since the downgrade after 3/7/21
49 additional answers
    2021-03-06T00:55:43+00:00
    Me too.
    I never had such a problem. It happened to me recently after the clean installation of Windows.
    2021-03-06T01:33:23+00:00
    Wouldn’t worry about it - this is strictly related to the most recent Office update. Yes - it’s annoying to see in Reliability Monitor - but you can delete the event if it annoys you - my assumption is it’s a one off crash due to some poor programming in the update.
    Don’t waste your time with the usual advice of online repair, uninstall, reinstall, SFC, DISM nonsense.
    2021-03-06T02:03:15+00:00
    Ryan, thanks a lot. It means a lot to know your input. Let's hope it will get fixed soon.
