OneDrive for Mac on Big Sur
2020-11-17T12:19:07+00:00
Hello everyone,
Since I've updated to Big Sur, OneDrive is eating a lot of resources. The vent of my Macbook is constantly running...
I've seen earlier discussions with other OS versions, however all tipps did not help (reset/reinstall/reset via terminal etc..).
Any ideas?
Cheers
Phil
2020-11-25T07:00:43+00:00
Hi All,
We are really sorry for the performance on OneDrive for Mac after you upgrade to latest Mac OS Big Sur, here is a summary for the issue with the suggestion that works for some members. We get information that the related developer team of OneDrive is working on fix and improvements to make sure OneDrive work well on Big Sur, Please keep your OneDrive up to date.
Issue Description:
OneDrive is taking up a lot of resource on Mac when syncing after upgrade to Mac OS Big Sur.
Environment:
OneDrive For Mac
Suggestion:
To make sure there are no compatible issue between OneDrive and Mac OS Big Sur. Please make sure OneDrive is up to date. You may update OneDrive by methods below:
Download standalone package( Download OneDrive for Mac (standalone .pkg) - Version 20.169.0823.0008 (October 16, 2020)
Update OneDrive to 20.169.0823 from Apple Store
For more information: OneDrive release notes
Additionally, please also turn off Anti-virus softwares on your Mac, as some users report the issue could be related to them. To check if the issue caused by other programs on MAC, please preform Mac Safe Mode: Apple Support article: How to use safe mode on your Mac
Regards,
Clark
2020-12-01T00:16:00+00:00
My problem was Avast. Any network filter such as anti-virus or LittleSnitch don't seem to be working well with Mac OS Big Sur yet. For me, Avast was blocking my gmail IMAP servers on Mail app and stopping my files from syncing on onedrive, dropbox etc..
For anti-virus un-install, dropping the application icon in the bin alone may not be enough to completely remove it. Follow the developer’s instructions for full un-install. For my instance, I just googled un-install Avast and followed the instructions and after I restarted the computer, onedrive and my emails started working flawlessly again.
Hope it helps!
49 additional answers
    2020-11-19T11:56:56+00:00
    Why would you turn OFF the finder integration? it is one of the most useful features.
    2020-11-19T14:41:44+00:00
    Hi Simon_Jones_
    Thanks for the post, there was users reporting the issue could be related to the integration, and disable it may solve the issue. Do you get the same issue after updating to Big Sur?
    Regards,
    Clark
    2020-11-19T14:55:34+00:00
    Yes, I am using Big Sur. OneDrive version 20.124.0621.0006, aka "hairdryer" because it makes the fans in my 2018 MBP blow so hard. I do not want to disable finder integration, I may as well not bother using OneDrive without it. Toggling it and rebooting has not had any effect either way, OneDrive is still a massive resource hog. I've had Big Sur since last weekend so it should have settled in by now. Currently reporting 98.6% CPU usage on uptime of four hours and top of the list for energy impact, by a factor of 10x!!!! And OneDrive Finder Integration running four times in my processes. This sucks.
