Click-to-Run High CPU Usage
2020-06-09T15:24:20+00:00
Recently I noticed that there was a background application constantly running on my PC called 'click-to-run'. It runs from the moment I switch on the PC and it never stops and even if I stop the task, it will simply start again. It uses around 25% CPU load and when opening an Office app, like Word, that app uses another 25%. I am using Office 365 which I downloaded through the Education bundle which they offer. Is there a fix for this high CPU load please?
2020-06-15T14:17:34+00:00
Hi All,
Thanks for the detailed information provided. We would like to make a short summary on this issue to help the other users who might have same/similar issues in this community to quickly identify the issue.
Issue Symptom:
When using the Office applications, they will use a lot of the CPU resources.
In the task manager, the Microsoft Office Click-to-Run(SxS) will consume 25%-50% of the CPU usage.
Issue Environment:
Microsoft 365 Apps with Current & Current(Preview) update Channel
Version 2005 (12827.20328)
Version 2005 (12827.20336)
Version 2005 (12827.20268)
Windows 10
Solution:
We are trying to escalate this issue to the related resources for further investigation.
Here are some of the methods provided by the users in this community:
1.Using Online Repair to repair your Office suite.
Repair an Office application
2.Some of the users reported this issue is only occurring when you are using a wireless connected to a limited network environment like 4G hot spot. Please use a WLAN connection or a LAN connection, see if it helps on this issue.
3.Install the available Windows OS updates.
Meanwhile, please kindly submit a feedback in the Office client:
How do I give feedback on Microsoft Office?
This will help us speed up the escalation process. Much appreciate for your effort and understanding.
Regards,
Alex Chen
51 additional answers
    2020-06-14T21:12:11+00:00
    Hello Hugo,
    I have also the same issue described here : https://answers.microsoft.com/en-us/msoffice/forum/msoffice_install-mso_win10-mso_o365b/office-365-for-enterprise-after-update-issue/235afcbc-e226-428c-a007-a4e00d991581?tm=1592079519208&auth=1
    For the info,
    the process C2R is always consuming 30% CPU if I use Wi-Fi or mobile hotspot.
    If I run other office application : skype for business, outlook, excel, the 100% is devided between C2R and the running apps.
    BR,
    Abderrahmen
    2020-06-15T08:03:16+00:00
    Hello Hugo,
    I have installed some updates in windows update and now it looks like the issue is resolved.
    BR,
    Abderrahmen
    2020-06-16T06:29:33+00:00
    ...had the same Problem. The fix was actually pretty easy for me, although it defeats the purpose of another setting:
    I had my internet connection set to "metered connection" in the connection properties. When I set this to off, then the problem goes away.
    The bug is reproduceable: set the metered connection to on, and the problem re-appears. Set it to off, and the problem is gone. (you need to restart the service and any office program currently running!)
    2020-06-17T11:13:08+00:00
    I had the same problem. It is completely reproducible. If on a metered connection , Click to run; and each of the office components, uses high CPU constantly, Turn metered connection off, not problems.
    Unfortunately I NEED to run on a  metered connection frequently. In this case, My CPU gets very hot so can't use it for any length of time. Defeats the whole purpose of a metered connection. Microsoft needs to fix this urgently.
