Click-to-Run High CPU Usage
2020-06-09T15:24:20+00:00
Recently I noticed that there was a background application constantly running on my PC called 'click-to-run'. It runs from the moment I switch on the PC and it never stops and even if I stop the task, it will simply start again. It uses around 25% CPU load and when opening an Office app, like Word, that app uses another 25%. I am using Office 365 which I downloaded through the Education bundle which they offer. Is there a fix for this high CPU load please?
2020-06-15T14:17:34+00:00
Hi All,
Thanks for the detailed information provided. We would like to make a short summary on this issue to help the other users who might have same/similar issues in this community to quickly identify the issue.
Issue Symptom:
When using the Office applications, they will use a lot of the CPU resources.
In the task manager, the Microsoft Office Click-to-Run(SxS) will consume 25%-50% of the CPU usage.
Issue Environment:
Microsoft 365 Apps with Current & Current(Preview) update Channel
Version 2005 (12827.20328)
Version 2005 (12827.20336)
Version 2005 (12827.20268)
Windows 10
Solution:
We are trying to escalate this issue to the related resources for further investigation.
Here are some of the methods provided by the users in this community:
1.Using Online Repair to repair your Office suite.
Repair an Office application
2.Some of the users reported this issue is only occurring when you are using a wireless connected to a limited network environment like 4G hot spot. Please use a WLAN connection or a LAN connection, see if it helps on this issue.
3.Install the available Windows OS updates.
Meanwhile, please kindly submit a feedback in the Office client:
How do I give feedback on Microsoft Office?
This will help us speed up the escalation process. Much appreciate for your effort and understanding.
Regards,
Alex Chen
51 additional answers
    2020-06-10T10:35:52+00:00
    Hi Hugo,
    Word still consumes a lot of CPU as well yes and Click-to-run is still running in the background. There are no more updates remaining, and when I close all office applications, Click-to-run still continues to work.z I will try to use the repair link you sent me.
    Regards,
    Stephen
    2020-06-10T10:41:29+00:00
    Also what I noticed it that whenever I open a new office app, for example word, for some time there will be two Click-to-run programs running and then one goes away. So there are two applications of the same thing running at once.
    2020-06-10T11:37:10+00:00
    Dear Hugo,
    I did the repair process that you suggested and installed the new office using that application rather than through the website from where I previously installed the education office bundle. There might be a problem with the installation procedure of this link:
    https://www.microsoft.com/en-us/education/products/office
    The problem appears to have been fixed and everything is in order. I appreciate your constant help and wish you a good day.
    Here is a screenshot after the new installation when I open Word:
    Best Regards,
    Stephen
    2020-06-11T06:53:07+00:00
    Hi Hugo,
    I am having this exact same problem. Only started a couple of days ago.
    I have updated Office 365, done an online repair and completely uninstalled and reinstalled multiple times without success.
    What I have noticed is that when I am not connected to the internet I do not have the problem at all.
    It is only when I am connected and I start an Office application, even a blank Word document, it runs at ~20% CPU but uses no other resources such as disk or network to suggest it is trying to update in the background. I have version 2005 (Build 12827.20268 Click-to-Run).
    Please assist.
