Click-to-Run High CPU Usage
2020-06-09T15:24:20+00:00
Recently I noticed that there was a background application constantly running on my PC called 'click-to-run'. It runs from the moment I switch on the PC and it never stops and even if I stop the task, it will simply start again. It uses around 25% CPU load and when opening an Office app, like Word, that app uses another 25%. I am using Office 365 which I downloaded through the Education bundle which they offer. Is there a fix for this high CPU load please?
2020-06-15T14:17:34+00:00
Hi All,
Thanks for the detailed information provided. We would like to make a short summary on this issue to help the other users who might have same/similar issues in this community to quickly identify the issue.
Issue Symptom:
When using the Office applications, they will use a lot of the CPU resources.
In the task manager, the Microsoft Office Click-to-Run(SxS) will consume 25%-50% of the CPU usage.
Issue Environment:
Microsoft 365 Apps with Current & Current(Preview) update Channel
Version 2005 (12827.20328)
Version 2005 (12827.20336)
Version 2005 (12827.20268)
Windows 10
Solution:
We are trying to escalate this issue to the related resources for further investigation.
Here are some of the methods provided by the users in this community:
1.Using Online Repair to repair your Office suite.
Repair an Office application
2.Some of the users reported this issue is only occurring when you are using a wireless connected to a limited network environment like 4G hot spot. Please use a WLAN connection or a LAN connection, see if it helps on this issue.
3.Install the available Windows OS updates.
Meanwhile, please kindly submit a feedback in the Office client:
How do I give feedback on Microsoft Office?
This will help us speed up the escalation process. Much appreciate for your effort and understanding.
Regards,
Alex Chen
51 additional answers
    2020-06-25T12:47:35+00:00
    The problem has been fixed in the latest version of Office 2019 v16.12827.20470. Update to this version and your problem will be fixed.
    Hope this helped.
    Thanks.
    2020-06-25T14:11:06+00:00
    If your office app does not offer the update automatically as happened on my system,
    1 select the File option from the ribbon,
    2 then select Account (lower region of left hand band), 3 then Update options,
    4 update now.
    Problems fixed.
    Regards
    KenBell6
    2020-06-25T14:27:21+00:00
    Thank you @kenBell6
    Yes, the issue was an update for WinWord which eventually did not stop ! I followed your advice, it updated WinWord then closed Click-to-run, this service is still running but 0% CPU and Office apps arenot using 25% of the CPU !
