Click-to-Run High CPU Usage
2020-06-09T15:24:20+00:00
Recently I noticed that there was a background application constantly running on my PC called 'click-to-run'. It runs from the moment I switch on the PC and it never stops and even if I stop the task, it will simply start again. It uses around 25% CPU load and when opening an Office app, like Word, that app uses another 25%. I am using Office 365 which I downloaded through the Education bundle which they offer. Is there a fix for this high CPU load please?
2020-06-15T14:17:34+00:00
Hi All,
Thanks for the detailed information provided. We would like to make a short summary on this issue to help the other users who might have same/similar issues in this community to quickly identify the issue.
Issue Symptom:
When using the Office applications, they will use a lot of the CPU resources.
In the task manager, the Microsoft Office Click-to-Run(SxS) will consume 25%-50% of the CPU usage.
Issue Environment:
Microsoft 365 Apps with Current & Current(Preview) update Channel
Version 2005 (12827.20328)
Version 2005 (12827.20336)
Version 2005 (12827.20268)
Windows 10
Solution:
We are trying to escalate this issue to the related resources for further investigation.
Here are some of the methods provided by the users in this community:
1.Using Online Repair to repair your Office suite.
Repair an Office application
2.Some of the users reported this issue is only occurring when you are using a wireless connected to a limited network environment like 4G hot spot. Please use a WLAN connection or a LAN connection, see if it helps on this issue.
3.Install the available Windows OS updates.
Meanwhile, please kindly submit a feedback in the Office client:
How do I give feedback on Microsoft Office?
This will help us speed up the escalation process. Much appreciate for your effort and understanding.
Regards,
Alex Chen
51 additional answers
    2020-06-24T19:07:22+00:00
    Hi Alex,
    Perhaps you can confirm my supposition. C2R.exe is the software that downloads office updates, hence after i allowed it to complete its work i am no longer seeing issues with this item, probably not until a new update becomes available?
    However we still have the issue starting any office app with metered connection on causes high cpu useage.
    Regards Ken
    2020-06-25T05:32:42+00:00
    Hi Ken,
    The Click to Run.exe is used to check the available updates and download/install the update package to your Office application.
    I think your idea is correct, since you have already updated to the latest version under current channel. I agree this issue is most likely related to C2R checking updates under a metered network connection.
    Regards,
    Alex Chen
    2020-06-25T05:37:42+00:00
    Same issue :
    1. Repair : no effect
    2. 4G (no LAN available #covid-19
    3. Click-to-run launch at start-up "forever" without any office app with 25% of the CPU
    4. each Office app launched also uses 25% of CPU even idle
    5. I stop "click-to-run in services.msc and change it from automatic to manual start but, still, it restarts when any office app is launched
    Help !
    Christian
    2020-06-25T12:35:15+00:00
    Hi Christian,
    May I suggest that you try the following, it works on my system.
    1 Stop 'click-to-run' in services.msc and set it to disabled.
    2 Block 'Microsoft Click to Run Virtualization Optimization' from connecting to the internet (I use Zone Alarm Firewall for this, there is a free version available, the same may be possible in Windows Firewall but I have never used it)
    3 Reset click-to-run to Automatic
    4 Whenever you need to open a new instance of any office app, ensure that you disconnect from the internet first. Once the instance is up and running you can reconnect to the internet.
    5 If you forget to disconnect first, close that instance, disconnect, then reopen it.
    Hope this helps.
    Regards Ken
