Click-to-Run High CPU Usage
2020-06-09T15:24:20+00:00
Recently I noticed that there was a background application constantly running on my PC called 'click-to-run'. It runs from the moment I switch on the PC and it never stops and even if I stop the task, it will simply start again. It uses around 25% CPU load and when opening an Office app, like Word, that app uses another 25%. I am using Office 365 which I downloaded through the Education bundle which they offer. Is there a fix for this high CPU load please?
2020-06-15T14:17:34+00:00
Hi All,
Thanks for the detailed information provided. We would like to make a short summary on this issue to help the other users who might have same/similar issues in this community to quickly identify the issue.
Issue Symptom:
When using the Office applications, they will use a lot of the CPU resources.
In the task manager, the Microsoft Office Click-to-Run(SxS) will consume 25%-50% of the CPU usage.
Issue Environment:
Microsoft 365 Apps with Current & Current(Preview) update Channel
Version 2005 (12827.20328)
Version 2005 (12827.20336)
Version 2005 (12827.20268)
Windows 10
Solution:
We are trying to escalate this issue to the related resources for further investigation.
Here are some of the methods provided by the users in this community:
1.Using Online Repair to repair your Office suite.
Repair an Office application
2.Some of the users reported this issue is only occurring when you are using a wireless connected to a limited network environment like 4G hot spot. Please use a WLAN connection or a LAN connection, see if it helps on this issue.
3.Install the available Windows OS updates.
Meanwhile, please kindly submit a feedback in the Office client:
How do I give feedback on Microsoft Office?
This will help us speed up the escalation process. Much appreciate for your effort and understanding.
Regards,
Alex Chen
51 additional answers
    2020-06-09T17:39:44+00:00
    I updated Office, unfortunately the problem still persists and Click-to-run still starts on boot up and still consumes 25% CPU constantly.
    This is my About section screenshot, hope it helps.
    Thanks in advance.
    [PII is masked by Hugo Liang MSFT Support]
    2020-06-09T17:26:13+00:00
    I did find some updates. I will do as you suggested and get back to you.
    Thank you for the speedy reply!
    2020-06-09T17:14:22+00:00
    Hello Stephen,
    Sorry to hear that.
    The Click-to-Run service is required during using Office and I would like to suggest you open one of Office applications, click File -> Account, on the right-hand Product Information panel, click Update Options -> Update Now. After updating and restarting Office application, you may check whether the Click-to-Run service still consuming high CPU resources.
    If the problem persists, could you upload a screenshot to show the update channel and detailed version of Office? I may directly do some tests with the specific Office suite.
    *On the Product Information panel, you can find the update channel and detailed version of Office on the About Word/Excel/PowerPoint section.
    We appreciate your feedback.
    Best Regards,
    Hugo
