Office Lens won't upload to Onedrive and stays in Transfering modus
2019-11-27T08:12:03+00:00
After making a picture in Office Lens, and saving is to Onedrive, more and more files keep transferring, trying to upload. This is not happening all times, but I think it has to do with the internet connection at the moment of saving. Normally, the transferring time is aborted by a time-out, and you can retry to upload the (pdf) file. Most times it works, but now is stays in transfering mode and I cannot access the picture anymore. Please support me.
    2020-01-28T09:39:39+00:00
    • Can you tell us if you have tried saving a different file to OneDrive? Is it having the same issue?
    • A: Many files do work. Only a few are stuck in transfer mode. The only option offered when I click it is to delete it. I don’t want to delete the PDF I made, I no longer have access to the papers.
    • Have you tried saving the Office Lens file to a different location like OneNote, Word, or in the Gallery of your device?
    • A: I can no longer get to the file as it is stuck in transfer mode. Surprising there is no way to cancel the transfer without deleting the file(!).
    • Did you notice if this concern is happening to other apps as well?
    • A: No, only Office Lens.
  2. Deleted
    2020-01-28T20:08:59+00:00
    This case is still under investigation and our internal support team is currently working on the issue. Please extend you patience on this case and if there would be updates, I will post it immediately.
    Regards,
    Bob
    2020-01-28T23:31:38+00:00
    Really, still under investigation, since November?  What about the new issue I presented with a picture just recently?
    2020-01-30T15:42:39+00:00
    I am experiencing exactly the same issue since November last year.  I had been using Office Lens syncing into OneNote extensively for over a year, but I now have images that are stuck 'transferring' exactly as described by other users.  I no longer have access to the original documents or images, so cannot simply delete and try again.  Is there any update on this please?
