Disk Utility warnings in OS X Mojave and OneDrive for mac
2018-12-26T09:46:26+00:00
OneDrive for Mac (v 18.222.1104.0007) is causing error in OS X Disk Utility (OS X Mojave 10.14.2 and 10.14.1):
warning: inode_val: object (oid 0xcb5b5): invalid bsd_flags (0x10)
Found this being OneDrive by re-installing the operating system and also by converting 0xcb5b5 to decimal format and running " find / -inum 832949 " in terminal.
I also send a support ticket but those tips didn't work (see bellow):
-------------------- START OF SUPPORT ANSWER -----------------------
Dear Customer,
You are now in contact with the support team by e-mail.
Regarding your issue please verify the following information in the article to check if the issue is related to this:https://support.microsoft.com/en-us/help/3125202/restrictions-and-limitations-when-you-sync-files-and-folders
After verifying the information above please continue to reset the OneDrive app:
1-Launch Activity Monitor & Kill OneDrive processes
2-Launch Keychain Access and delete OneDrive keys
3-End OneDrive processes and Keys
4-First, navigate to the OneDrive application. Then you Control-click the application. When you do that, you should see the following menu appear:
5-From that menu, select “Show Package Contents”. You will then see a list of folders and files within the OneDrive application. Note: don’t mess with things in here as it could break your application.
6-Within the “Contents” folder, scroll down to the “Resources” folder.
Search for: ResetOneDriveAppStandalone.command
It’s not an application. It just a script that is run in the terminal. Note, when you run it, you may need to authenticate as an administrator.
To run the script, just double-click on it. It should launch Terminal and run through a variety of options. Once it has finished, you are done!
7-Once you have run the script (and already did the other 2 items earlier), you should be able to launch OneDrive as if it were a completely new installation. You should be prompted to enter your login information and start synchronizing.
------------------------- END OF SUPPORT MESSAGE --------------------------
Only thing happened after "clean install of OneDrive" was that the DiskUtility error is now this (the object value has changed):
warning: inode_val: object*(oid 0x1281e1**): invalid bsd_flags (0x10)*
Is this a known problem or something new?
2019-02-18T06:17:22+00:00
Hi All,
Thanks for letting us know your situation and sharing your experience here. We totally understand your frustration for encountering this, we are always more than willing to help all users in this community.
We have discussed internally with higher level support resources on this issue. Disk Utility error warnings occur from Mac Disk Utilities and Terminal since both are Apple products, it is hard for us to get the source code for further investigation even though we would like to do. We also do not understand the logic it used to flag the OneDrive at first place. So we believe it is the best to reach out to Apple support first for this case.
From our side, a support ticket number is required for our product team to check more details if you still need our help. Once the ticket is created, please post back here as soon as you can. We will contact our related team again then.
We really appreciate your understanding.
Yoga
83 additional answers
    2019-01-20T00:33:33+00:00
    I'm having the exact same problem with the inode flag, and it ALWAYS points to OneDrive.   I was wondering if anyone had found a solution to this problem, because my entire system seems to have issues now, and I really believe it's because of this.
    Thank you all
    Shana
    2019-01-20T18:13:28+00:00
    Hi Guy and Shana,
    Thank you for your feedback regarding this.
    We are reporting this issue and it might take some time to confirm the details. Once we have any update, we will renew our information to let you know. We also appreciate your patience and attention.
    Best Regards,
    Eli
    2019-01-20T21:26:11+00:00
    Hi Guy and Shana,
    Best Regards,
    Eli
    Hi Eli,
    I do not think it is fair to be payong full price for Office 365 and have  a nom-functional desktop application that eats my files and messes my system up. This mist have something to do with the directory created by outlook itself.  I think until you find a solution to this problem affecting so many of us, the least  the Microsoft crew should do is give some subscription discount until fixed.  As memtioned by others, I cannot use the smart sync feature, or any feature, since I use OneDrive with the other Office applications to collaborate with others
    2019-01-20T21:58:09+00:00
    Hi Guy and Shana,
    Best Regards,
    Eli
    Confirm the details? Reporting the issue?
    This thread has already mentioned that the Microsoft OneDrive developer team had reproduced the issue on a fresh install of MacOS 10.14!
    I hope you are past the "reporting the issue"! This should have been done a month ago!
    What is going on? Is no one qualified enough to correct an issue that affects the file system of the operating system!
    How can an app cause so much trouble?
    How long are you guys going to continue telling us that "you are reporting the issue" and "it might take some time to confirm the details".
    This issue has been reported more than 45 days ago!
