Disk Utility warnings in OS X Mojave and OneDrive for mac
2018-12-26T09:46:26+00:00
OneDrive for Mac (v 18.222.1104.0007) is causing error in OS X Disk Utility (OS X Mojave 10.14.2 and 10.14.1):
warning: inode_val: object (oid 0xcb5b5): invalid bsd_flags (0x10)
Found this being OneDrive by re-installing the operating system and also by converting 0xcb5b5 to decimal format and running " find / -inum 832949 " in terminal.
I also send a support ticket but those tips didn't work (see bellow):
-------------------- START OF SUPPORT ANSWER -----------------------
Dear Customer,
You are now in contact with the support team by e-mail.
Regarding your issue please verify the following information in the article to check if the issue is related to this:https://support.microsoft.com/en-us/help/3125202/restrictions-and-limitations-when-you-sync-files-and-folders
After verifying the information above please continue to reset the OneDrive app:
1-Launch Activity Monitor & Kill OneDrive processes
2-Launch Keychain Access and delete OneDrive keys
3-End OneDrive processes and Keys
4-First, navigate to the OneDrive application. Then you Control-click the application. When you do that, you should see the following menu appear:
5-From that menu, select “Show Package Contents”. You will then see a list of folders and files within the OneDrive application. Note: don’t mess with things in here as it could break your application.
6-Within the “Contents” folder, scroll down to the “Resources” folder.
Search for: ResetOneDriveAppStandalone.command
It’s not an application. It just a script that is run in the terminal. Note, when you run it, you may need to authenticate as an administrator.
To run the script, just double-click on it. It should launch Terminal and run through a variety of options. Once it has finished, you are done!
7-Once you have run the script (and already did the other 2 items earlier), you should be able to launch OneDrive as if it were a completely new installation. You should be prompted to enter your login information and start synchronizing.
------------------------- END OF SUPPORT MESSAGE --------------------------
Only thing happened after "clean install of OneDrive" was that the DiskUtility error is now this (the object value has changed):
warning: inode_val: object*(oid 0x1281e1**): invalid bsd_flags (0x10)*
Is this a known problem or something new?
2019-02-18T06:17:22+00:00
Hi All,
Thanks for letting us know your situation and sharing your experience here. We totally understand your frustration for encountering this, we are always more than willing to help all users in this community.
We have discussed internally with higher level support resources on this issue. Disk Utility error warnings occur from Mac Disk Utilities and Terminal since both are Apple products, it is hard for us to get the source code for further investigation even though we would like to do. We also do not understand the logic it used to flag the OneDrive at first place. So we believe it is the best to reach out to Apple support first for this case.
From our side, a support ticket number is required for our product team to check more details if you still need our help. Once the ticket is created, please post back here as soon as you can. We will contact our related team again then.
We really appreciate your understanding.
Yoga
83 additional answers
    2018-12-28T09:16:20+00:00
    Hi janveCI,
    Thanks for your detailed information.
    Per my test on Mojave 10.14.2 and the same OneDrive (v 18.222.1104.0007), I cannot reproduce this error message on my side.
    According to your Terminal screenshot, it allows to access OneDrive sync folder but no extra information mentioned. Does this warning affect your Mac? Can your OneDrive work fine currently?
    We also receive the ticket number provided in PM. However, we don't find anything via this number. It seems not to be a Microsoft Service Request ticket. Is it Apple Support who directs you to check this warning?
    Considering the warning occurs after installing OneDrive and you have reset OneDrive, does the warning disappear when you remove OneDrive but emerge if OneDrive is reinstalled?
    Regards,
    Eli
    Thanks for the fast reply. This warning doesn't seem to have any other impact but the warning that disk utility gives (quite hard to figure out if it really has any impact or not) and OneDrive app seems to work as it should. As Catalambano said earlier, when removing the OneDrive and all related content, the warning disappears. Btw. I'm on Macbook Pro mid 2018 15" 256Gb.
    The ticket number was received after sending a message through the one drive app. Got the answer from the address "Microsoft OneDrive Support <odrvhelp@****>" and the number I gave you in PM was placed in the subject of the message (OneDrive account is a enterprise / university account - don't know if this makes any changes if you are trying to find the right ticket)
    2018-12-30T16:24:57+00:00
    Hi janveCI,
    Thank you for the update. I'm on weekend so sorry for the delay.
    Since this warning seems not to affect anything on your end , it might be a little difficult for us to troubleshot this cause of the warning which provided by Disk Utility but it does not provide more details. So I would suggest you continue troubleshooting the warning with OneDrive support and I will consult if the ticket number can be available.
    In the meantime, as I mentioned regarding remove warning: inode_val: object : invalid bsd flags, you could also vote and comment this for further attention. If we have any update regarding this warning, we will post back and let you know.
    Best Regards,
    Eli
    2018-12-31T14:50:17+00:00
    Hi Catalambano,
    Seems this warning affects full system recovery from the time machine backup on your end. If you pause syncing up, does the feature works successfully?
    Besides, have you got the same warning code as janveCI posted in the question? Could you share the warning code with us?
    @janveCI,
    OneDrive Support are available for personal OneDrive instead of work/school account. in the meantime, we support OneDrive for Business with work/school account.
    Regards,
    Eli
    2019-01-06T13:43:39+00:00
    I have the exact same problem and the command "find / -inum xxx(my inode number converted in decimal)" also points to a folder managed by Microsoft OneDrive.
    This is a CRITICAL bug as it results in the impossibility of fully recovering from backup and thus to potential data loss!
    This is thus very serious (data loss is one of the worst failure cases that can happen in IT) and needs to be resolved.
    This bug has been introduced since the last update(s) of OneDrive as the previous versions didn't trigger this error (I have checked this).
