Disk Utility warnings in OS X Mojave and OneDrive for mac
2018-12-26T09:46:26+00:00
OneDrive for Mac (v 18.222.1104.0007) is causing error in OS X Disk Utility (OS X Mojave 10.14.2 and 10.14.1):
warning: inode_val: object (oid 0xcb5b5): invalid bsd_flags (0x10)
Found this being OneDrive by re-installing the operating system and also by converting 0xcb5b5 to decimal format and running " find / -inum 832949 " in terminal.
I also send a support ticket but those tips didn't work (see bellow):
-------------------- START OF SUPPORT ANSWER -----------------------
Dear Customer,
You are now in contact with the support team by e-mail.
Regarding your issue please verify the following information in the article to check if the issue is related to this:https://support.microsoft.com/en-us/help/3125202/restrictions-and-limitations-when-you-sync-files-and-folders
After verifying the information above please continue to reset the OneDrive app:
1-Launch Activity Monitor & Kill OneDrive processes
2-Launch Keychain Access and delete OneDrive keys
3-End OneDrive processes and Keys
4-First, navigate to the OneDrive application. Then you Control-click the application. When you do that, you should see the following menu appear:
5-From that menu, select “Show Package Contents”. You will then see a list of folders and files within the OneDrive application. Note: don’t mess with things in here as it could break your application.
6-Within the “Contents” folder, scroll down to the “Resources” folder.
Search for: ResetOneDriveAppStandalone.command
It’s not an application. It just a script that is run in the terminal. Note, when you run it, you may need to authenticate as an administrator.
To run the script, just double-click on it. It should launch Terminal and run through a variety of options. Once it has finished, you are done!
7-Once you have run the script (and already did the other 2 items earlier), you should be able to launch OneDrive as if it were a completely new installation. You should be prompted to enter your login information and start synchronizing.
------------------------- END OF SUPPORT MESSAGE --------------------------
Only thing happened after "clean install of OneDrive" was that the DiskUtility error is now this (the object value has changed):
warning: inode_val: object*(oid 0x1281e1**): invalid bsd_flags (0x10)*
Is this a known problem or something new?
2019-02-18T06:17:22+00:00
Hi All,
Thanks for letting us know your situation and sharing your experience here. We totally understand your frustration for encountering this, we are always more than willing to help all users in this community.
We have discussed internally with higher level support resources on this issue. Disk Utility error warnings occur from Mac Disk Utilities and Terminal since both are Apple products, it is hard for us to get the source code for further investigation even though we would like to do. We also do not understand the logic it used to flag the OneDrive at first place. So we believe it is the best to reach out to Apple support first for this case.
From our side, a support ticket number is required for our product team to check more details if you still need our help. Once the ticket is created, please post back here as soon as you can. We will contact our related team again then.
We really appreciate your understanding.
Yoga
83 additional answers
    2019-02-15T14:50:48+00:00
    Hi Shana,
    Thanks for your reply. I have sent you a private message to collect the service request number. Please access it via this link.
    Regards,
    Rena
    2019-02-15T19:13:44+00:00
    My OneDrive folder was on my boot disk, and I got these errors in Disk First Aid. I have another disk for data that never had the errors. I moved my OneDrive folder to the other disk, unlinked OneDrive from the original disk, and re-linked it to the new folder on the other disk. I used CCC to delete all the snapshots from the boot disk,
    The result was that Disk First Aid showed no errors on the boot disk (first time in months !!) and now showed the error on the disk I just moved the OneDrive folder too.
    I don't know what additional proof is needed for Microsoft to take ownership of this and work with Apple to get the root cause.
    While I'm not a Business customer, I am an Office 365 customer.
    2019-02-17T09:27:45+00:00
    I have two business 365 accounts that include OneDrive and I'm having the same issue.  Happy to capture details if that helps.
    2019-02-17T16:50:40+00:00
    It is the db file within the OneDrive folder. Not sure if it is created by the app it's self or is downloaded from a Microsoft server but after a few experiments on Sat and Sin on two different Mac's I finally got rid of the warning in Recovery. I had moved the OneDrive folder to the Downloads Folder and renamed it to xxxDrive and thought that it might work. After a few trials of Recovery mode I went back and created a new folder and dragged everything out of it except the db file and one other one that escapes my memory. I then rebooted into Recovery mode and ran Repair. No warnings at all.
