Disk Utility warnings in OS X Mojave and OneDrive for mac
2018-12-26T09:46:26+00:00
OneDrive for Mac (v 18.222.1104.0007) is causing error in OS X Disk Utility (OS X Mojave 10.14.2 and 10.14.1):
warning: inode_val: object (oid 0xcb5b5): invalid bsd_flags (0x10)
Found this being OneDrive by re-installing the operating system and also by converting 0xcb5b5 to decimal format and running " find / -inum 832949 " in terminal.
I also send a support ticket but those tips didn't work (see bellow):
-------------------- START OF SUPPORT ANSWER -----------------------
Dear Customer,
You are now in contact with the support team by e-mail.
Regarding your issue please verify the following information in the article to check if the issue is related to this:https://support.microsoft.com/en-us/help/3125202/restrictions-and-limitations-when-you-sync-files-and-folders
After verifying the information above please continue to reset the OneDrive app:
1-Launch Activity Monitor & Kill OneDrive processes
2-Launch Keychain Access and delete OneDrive keys
3-End OneDrive processes and Keys
4-First, navigate to the OneDrive application. Then you Control-click the application. When you do that, you should see the following menu appear:
5-From that menu, select “Show Package Contents”. You will then see a list of folders and files within the OneDrive application. Note: don’t mess with things in here as it could break your application.
6-Within the “Contents” folder, scroll down to the “Resources” folder.
Search for: ResetOneDriveAppStandalone.command
It’s not an application. It just a script that is run in the terminal. Note, when you run it, you may need to authenticate as an administrator.
To run the script, just double-click on it. It should launch Terminal and run through a variety of options. Once it has finished, you are done!
7-Once you have run the script (and already did the other 2 items earlier), you should be able to launch OneDrive as if it were a completely new installation. You should be prompted to enter your login information and start synchronizing.
------------------------- END OF SUPPORT MESSAGE --------------------------
Only thing happened after "clean install of OneDrive" was that the DiskUtility error is now this (the object value has changed):
warning: inode_val: object*(oid 0x1281e1**): invalid bsd_flags (0x10)*
Is this a known problem or something new?
2019-02-18T06:17:22+00:00
Hi All,
Thanks for letting us know your situation and sharing your experience here. We totally understand your frustration for encountering this, we are always more than willing to help all users in this community.
We have discussed internally with higher level support resources on this issue. Disk Utility error warnings occur from Mac Disk Utilities and Terminal since both are Apple products, it is hard for us to get the source code for further investigation even though we would like to do. We also do not understand the logic it used to flag the OneDrive at first place. So we believe it is the best to reach out to Apple support first for this case.
From our side, a support ticket number is required for our product team to check more details if you still need our help. Once the ticket is created, please post back here as soon as you can. We will contact our related team again then.
We really appreciate your understanding.
Yoga
83 additional answers
    2019-02-03T02:26:35+00:00
    Yes, I have run the terminal commands, I have tried all the suggested "fixes" in this thread, and every single time, it's the OneDrive folder that is the culprit.  I don't use Utorrent, whatever that is.  I just have a 365 subscription, which should give me a WORKING version of OneDrive, not one that sends up flag after flag, no matter how many times I uninstall and reinstall, and no matter how many times I check the Terminal, it ALWAYS is the OneDrive folder.  This is Microsoft's problem to solve, not ours, and it's absolutely unacceptable that I, and all others affected by this very obvious bug in YOUR source code, must cope with everlasting flags.  These flags are not simply a drag, they are a WARNING.  Please fix it ASAP, or offer your customers something to alleviate their inconvenience.
    Shana
    2019-02-03T10:57:18+00:00
    Could not have said this better. Thank you! This should have been fixed by now.
    2019-02-04T15:01:53+00:00
    Hi Shana,
    I have sent a private message to you. Have you received that?
    We have communicated with the related team but they prefer to check the case from Apple side. In this scenario, we would like to try again with a service request ticket to show the business impact. Really appreciate if you can help us to create one.
    Sorry for the inconvenience but we are still monitoring this thread and we really would like to help you further.
    Regards,
    Rena
    2019-02-04T16:30:56+00:00
    Still an issue with 10.14.3. I removed the OneDrive app and OneDrive folder but I am still getting the error message. Anyone have any ideas?
