Disk Utility warnings in OS X Mojave and OneDrive for mac
2018-12-26T09:46:26+00:00
OneDrive for Mac (v 18.222.1104.0007) is causing error in OS X Disk Utility (OS X Mojave 10.14.2 and 10.14.1):
warning: inode_val: object (oid 0xcb5b5): invalid bsd_flags (0x10)
Found this being OneDrive by re-installing the operating system and also by converting 0xcb5b5 to decimal format and running " find / -inum 832949 " in terminal.
I also send a support ticket but those tips didn't work (see bellow):
-------------------- START OF SUPPORT ANSWER -----------------------
Dear Customer,
You are now in contact with the support team by e-mail.
Regarding your issue please verify the following information in the article to check if the issue is related to this:https://support.microsoft.com/en-us/help/3125202/restrictions-and-limitations-when-you-sync-files-and-folders
After verifying the information above please continue to reset the OneDrive app:
1-Launch Activity Monitor & Kill OneDrive processes
2-Launch Keychain Access and delete OneDrive keys
3-End OneDrive processes and Keys
4-First, navigate to the OneDrive application. Then you Control-click the application. When you do that, you should see the following menu appear:
5-From that menu, select “Show Package Contents”. You will then see a list of folders and files within the OneDrive application. Note: don’t mess with things in here as it could break your application.
6-Within the “Contents” folder, scroll down to the “Resources” folder.
Search for: ResetOneDriveAppStandalone.command
It’s not an application. It just a script that is run in the terminal. Note, when you run it, you may need to authenticate as an administrator.
To run the script, just double-click on it. It should launch Terminal and run through a variety of options. Once it has finished, you are done!
7-Once you have run the script (and already did the other 2 items earlier), you should be able to launch OneDrive as if it were a completely new installation. You should be prompted to enter your login information and start synchronizing.
------------------------- END OF SUPPORT MESSAGE --------------------------
Only thing happened after "clean install of OneDrive" was that the DiskUtility error is now this (the object value has changed):
warning: inode_val: object*(oid 0x1281e1**): invalid bsd_flags (0x10)*
Is this a known problem or something new?
2019-02-18T06:17:22+00:00
Hi All,
Thanks for letting us know your situation and sharing your experience here. We totally understand your frustration for encountering this, we are always more than willing to help all users in this community.
We have discussed internally with higher level support resources on this issue. Disk Utility error warnings occur from Mac Disk Utilities and Terminal since both are Apple products, it is hard for us to get the source code for further investigation even though we would like to do. We also do not understand the logic it used to flag the OneDrive at first place. So we believe it is the best to reach out to Apple support first for this case.
From our side, a support ticket number is required for our product team to check more details if you still need our help. Once the ticket is created, please post back here as soon as you can. We will contact our related team again then.
We really appreciate your understanding.
Yoga
83 additional answers
    2019-01-31T09:13:04+00:00
    So we're lying ? We got the problem on the 3 version 10.14.1 to 10.14.3 !!!!
    I want just to remember you that we're r professionals using your software and paying monthly for this usage.
    May be we have to go to courts to get you respecting your contract and force you to pay for our data degradation.
    Waiting for a professional answer ant not a BS.
    Walid
    2019-02-01T03:03:40+00:00
    Hi All,
    Thanks for the new information. We have heard the voice from you. We would like to try more to see whether we can do anything further to help you. To do that, we need your help below:
    If you are the Office 365 Business customers (and non-premier customers), please help to create a support ticket via Office 365 admin Center > Support > New Service Request. Once the ticket is created, please post back here in the private message (Please access it via this link) as soon as you can. We will try to communicate with the related team again with it.
    The ticket can show the business impact in another way. Therefore, we will appreciate you can help us do that.
    Regards,
    Rena
    2019-02-01T06:35:26+00:00
    I’m a personal user, but I pay Office 365 too!!!
    2019-02-03T02:18:58+00:00
    We are now in Mojave 10.14.3, and thus, the issue should have been resolved by Microsoft in conjunction with Apple, ESPECIALLY since Apple is now carrying all the Microsoft applications natively on the Mac.  It is absolutely unfair to users to continue to side step the issue, as we are paying customers affected by this bug. I am praying the latest upgrade will solve the problem, but if not, it is not up to users to complain to Apple but up to Microsoft, which has a contract with Apple to carry it's products.  There is clearly something amiss in the source code, and that must be taken care of immediately.
