The procedure entry point EnumCalendarinfoExEx could not be located in the dynamic link library kernel32.dll
2019-01-23T16:00:56+00:00
Good day team.
We're getting this when opening any document in office 2010. We're running it on WinXP SP3 32 bits.
"The procedure entry point EnumCalendarinfoExEx could not be located in the dynamic link library kernel32.dll"
Haven't found any solution so far, all help is welcome.
2019-01-23T23:18:47+00:00
OMG! I was having the same error message "The procedure entry point EnumCalendarInfoExEx could not be located in the dynamic link library Kernel32.dll" So I checked to see what updates had been installed since I was in the office last week... KB4462157 on 1/18/2019. Uninstalled that one and Excel is now working! I hope this fix works for you as well.
75 additional answers
    2019-02-12T07:59:58+00:00
    Thanks so much SierraAerie this happened to me today and deleting the KB4462157 file worked.  Mind you it took me a long time to find the file as there were no dates displayed beside the updates and I had to read through the whole list until I found it.  Took a while to uninstall too and I thought at first it wasn't going to work.
    2019-02-13T08:24:23+00:00
    Unistall the update KB4462157 MSOffice.
    Bye.
    2019-02-14T19:45:41+00:00
    Is there another update causing this same problem?  KB4462157 is not listed anymore and my computer updated last night 2/13/19. everything was working fine but today it has this same problem again
    2019-02-14T22:59:33+00:00
    Hi Sonya
    Look for update KB4462174 and delete that - that fixed my problem after it re-occurred.  To prevent the unwanted updates from coming back you need to go to Control Panel/Classic View/Automatic Updates and instead of ticking "turn off automatic updates" tick "notify me but don't automatically download or install them".  Then, when you get the yellow shield in the task bar advising that there are updates ready you should download them and untick the ones that you don't want, e.g. 4461614, 4462157, 4462174, and then tick the box that comes up asking "don't notify me again about these".  That gets rid of them for good - he says with fingers crossed.
    Cheers
    John Taylor
