The procedure entry point EnumCalendarinfoExEx could not be located in the dynamic link library kernel32.dll
2019-01-23T16:00:56+00:00
Good day team.
We're getting this when opening any document in office 2010. We're running it on WinXP SP3 32 bits.
"The procedure entry point EnumCalendarinfoExEx could not be located in the dynamic link library kernel32.dll"
Haven't found any solution so far, all help is welcome.
2019-01-23T23:18:47+00:00
OMG! I was having the same error message "The procedure entry point EnumCalendarInfoExEx could not be located in the dynamic link library Kernel32.dll" So I checked to see what updates had been installed since I was in the office last week... KB4462157 on 1/18/2019. Uninstalled that one and Excel is now working! I hope this fix works for you as well.
75 additional answers
    2019-02-04T05:31:30+00:00
    Yes, this worked for me.  However, I found that the update in question kept on being re-installed until I turned off automatic updates and then followed the prompts to not have this one come back.
    2019-02-04T21:23:43+00:00
    I had to do the same thing.
    2019-02-04T21:26:15+00:00
    I don't get XP Security updates anymore...Just Office 2010 updates.
    2019-02-11T23:59:47+00:00
    I have had the same problem and rectified it by removing Update KB4462157 but the strange thing is that I have had Automatic Updates turned off since about 2012 and never manually install any updates. Consequently I'm a bit perplexed as to how I am going to stop this update from reinstalling when it has obviously installed despite the fact that I have it all turned off. Can anyone help me to make sure that this update doesn't reinstall?
