The procedure entry point EnumCalendarinfoExEx could not be located in the dynamic link library kernel32.dll
2019-01-23T16:00:56+00:00
Good day team.
We're getting this when opening any document in office 2010. We're running it on WinXP SP3 32 bits.
"The procedure entry point EnumCalendarinfoExEx could not be located in the dynamic link library kernel32.dll"
Haven't found any solution so far, all help is welcome.
2019-01-23T23:18:47+00:00
OMG! I was having the same error message "The procedure entry point EnumCalendarInfoExEx could not be located in the dynamic link library Kernel32.dll" So I checked to see what updates had been installed since I was in the office last week... KB4462157 on 1/18/2019. Uninstalled that one and Excel is now working! I hope this fix works for you as well.
75 additional answers
    2019-02-02T22:21:12+00:00
    Click the Start button, then Settings, select Control Panel, then Automatic Updates.  In the dialog box that opens check "Download updates for me, but let me choose when to install them".  This should uncheck "Automatic".  Click OK.  The updates will be downloaded as they become available and the yellow, shield-shaped Updates Available icon will show on the task bar.  Then follow the above procedure to disable and hide the updates you don't want to install.
    Microsoft no longer supports Windows XP.  Support ended in 2014.  Follow this link for more info.   https://www.microsoft.com/en-us/windowsforbusiness/end-of-xp-support?SilentAuth=1&wa=wsignin1.0
    I don't know why we keep getting updates.  It might have something to do with Win XP automatic updates feature still looking for changes we didn't install.
    2019-02-02T22:42:21+00:00
    I finally figured that out for myself yesterday, but thank you anyway for taking the time to respond.
    John
    2019-02-03T01:46:03+00:00
    In Control Panel open the Add, Delete or Change Programs item.  Be sure the Show Updates box is checked.  The list will show your programs and installed updates.  Select the one you want to uninstall and click the button at the right hand end of the name.
    2019-02-04T00:42:25+00:00
    Thank you very much. I have been working 24 hours on this and was getting ready to install LibreOffice.
