The procedure entry point EnumCalendarinfoExEx could not be located in the dynamic link library kernel32.dll
2019-01-23T16:00:56+00:00
Good day team.
We're getting this when opening any document in office 2010. We're running it on WinXP SP3 32 bits.
"The procedure entry point EnumCalendarinfoExEx could not be located in the dynamic link library kernel32.dll"
Haven't found any solution so far, all help is welcome.
2019-01-23T23:18:47+00:00
OMG! I was having the same error message "The procedure entry point EnumCalendarInfoExEx could not be located in the dynamic link library Kernel32.dll" So I checked to see what updates had been installed since I was in the office last week... KB4462157 on 1/18/2019. Uninstalled that one and Excel is now working! I hope this fix works for you as well.
75 additional answers
    2019-03-13T01:54:16+00:00
    I'm getting the same error. I tried to find the "KB4462157" update to remove it, but it's not in the list of updates. I'm running Office 2010 on Windows XP. Any other updates I should look for?
    2019-03-13T02:23:28+00:00
    Earl, any of the updates done this year are suspect. Do a websearch for Microsoft Office updates 2019 then look for those numbers and delete them.
    2019-03-13T02:57:44+00:00
    Please read the complete thread for this problem.  The answer to your question has already been posted.
    2019-03-13T16:50:48+00:00
    I reinstalled office and it worked. I forgot to turn off auto updates and it updated and problem came back.
    I just went thru and deleted every single KB that was listed as either 2019 or related to the Japanese calendar thing. Rebooted and it still does not work.
    I guess my only choice might be to uninstall again and not allow any updates, including all the ones from the past year or so that have nothing to do with this issue...OR..any other suggestions?
